Type Flex have been replaced by Monoflex, which on paper should be better then the Super Streets as they are monotube. But i have not driven a car with them, whereas the SS i have and liked them. I would be running them if i didnt get the RA tweaked. The SS seem to be the easy turn key package that gives you soem flexibility with playing with ride heights to get right then damping to play with. Bilsteins were a decent enough thing in my car but as an off the shelf package they are not sport enough in my opinion for a weekend track/club car.
You need to have played a little with them as djr81 has
  • Replies 119
Posted Images
So its:
Super street Front 5kg/mm, rear 4kg/mm
Mono Flex 7/7
Ultimate Spec Circuit Master Super Racing 12/12
What then are the RA/RE's?
The Bilsteins appear to be happy on a GT-R with a 5kgmm/4kgmm spring rate but I do not know how much higher you can go on spring rates without them being revalved. AFAIK the damper rates for 5/4kg springs are the same as those for the Whiteline springs. I have those rates somewhere & will dig them out.
Well it seems the $ and Yen has made anything from Tein SIGNIFICANTLY more expensive than they used to be. Apparently there is no old stock in the country, so new pricing even on the SS models are equal to or even more expensive than the Bilstein B6/8.....
I had a long chat with Centreline today and in his opinion (price aside) I need more than the Super Street. From the Tein range he suggested Monoflex as a minimum. He also offers Bilstein stuff too. They'll more or less do the same deal as Quadrant, but interestingly may have an option for some PSS9s which will be modified from R34 GTR items to fit the R32......I'll put them on the spot tomorrow to see how deliverable this really is. They will end up $500 more expensive than the std B6/8 Bilstein option.
Thanks for all the input so far.
and then there are these...
http://www.buddyclub.com.au/
N+ $2,300 or Racing Spec. 'three thousand and something'......Apparently there is no stock at all in the country and no-one knows when there will be. I'm getting a call back apparently.
So, Tein are apparently re-negotiating with Fulcrum as they've sold nothing this year because of the currency situation, but at this stage are out on pricing. Bilstein do not make a coilover apart from the PSS9 which is expensive and no longer available for an R32 GTR (last 8 kits sold the Unique Autosports), but someone is looking into adapting an R34 kit to suit. Lastly there is a 'home made' coil over kit, built up from the Bilstein B6/8 damper unit. At least this is available, has custom springs and damper valving. But we can all guess it's going to cost me.
So apparently if you have an R32 GTR its 'home made' Bilsteins or nothing right now....
Good info. So does Unique have any PSS9's left?
No.
One crucial question is: What spring rates are you going to run?
Dunno. Once I settle on what I'm buying and from who, I'll then worry about that detail. Plenty of good info on this post and I'll start researching
I'm running 650lb springs in the front, but not sure what Ben from Racepace put in the rears. Will have a look on the weekend.
All this metric stuff is too hard to understand!!!
Go metric man, its not 1965 anymore. :)
650lb/in approx equals 11.6kg/mm. Kinnard in otherwords.
I'd guess the rears would be about 550lb/inch.
Does your avatar show the car with those spring rates?
Edited by djr81
Yeah it does, the picture was taken as I was coming out of honda (turn 4) at Phillip Island.
Go metric man, its not 1965 anymore. :sweat:
I have a set of PSS9's for my R33 GTR waiting to go on and what I was told by a fella from Bilstein Australia was that the max on the front was 650lb/in and the rear 450lb/in. I would express that in metric but can't be assed converting.
Mike
Hi just thought i would add i have A R32 GTR and have the new Tein monoflex coil overs and with the stock rims my car handles great and the best of all is very comfortable on the road.
I dont have a very good back and i will say that these are awesome bit of kit.
A few of my friends have had the super streets they are a little softer but are not base height adjustable so when you lower the car it starts to compress the springs and they dont handle and feel as good anymore.
I know they are expensive but damn you can have a very good handling street and track car with these.
Just my 2 cents of info.
The search is over. I've found these Killabee Coilovers! That bee sure looks tough. LOL at whoring my own thread.
I've got a couple of second hand options now. Revalved Bilsteins, and some Ohlins (more details to come), so I'll get the detail on here ASAP.
A couple of cornering shots, both with the same setup, it picks up the inside front a bit....
Good shots. My thing is approx the same but doesn't quite lift the inside front. This is possibly because I run a Cusco rear sway bar rather than the Whiteline. In spring rate it works out to be 20% harder. My springs proper are softer than yours.
The worry I have is that if you do lose contact on the front inside then there is no way you will get any gain from having an AWD system. No front LSD means the inside front will just bag up.
As an aside I would love to know what the damper forces (bump & rebound) are for the Bilstein shocks used on the R32 GT-Rs, ie the
B46 1471 (Front)
B46 1472 (Rear).
There would, presumably, be a range of springs with which they work.
Equally I would imagine the damping forces would be greater on a 'revalved' shock built to accomodate a harder spring.
If anyone knows this stuff it would be great to pass on. It may also help people with adjustable shocks - providing ofcourse they have the velocity - damping force graphs for the various adjustments....
Edited by djr81
B46 1471 (Front)
B46 1472 (Rear).
I get virtually no front drive through the apex of corners with any more than 10% of lock on anyway, as that's the way I understand the ATTESSA logic works. I've got a torque split adjuster that can alter it however I find I need the grip more when the car is straightened up and the right foot gets planted. In that instance the lift has gone and the front drive is doing its thing.
I've never driven a GT-R with a front LSD so have no idea how much of a difference it would make. In my old Sti it was a huge difference, but the two 4WD systems are vastly different.
The TEIN RE's that I've got have had the bump valving tricked up for the big springs, with a view to making ripple strip hits a non issue. The shock dyno graphs interestingly show very little difference between the two adjustment extremes.
This may make you physically ill (you have been warned) but here is how the Emo boys do it. Notice how early in the corner the driver is on the gas. I think that is most of the reason they brain the GT-Rs in mickey mouse kharna stuff.
I found a huge diference in the car when I found some more front end grip. It meant that I could get onto the power alot earlier. It may well be the attessa/steering lock interaction you mentioned. Is it 10 degrees steering wheel movement or 10 degree road wheel movement?
Oh and I still owe you some DL1 data. I will get it sorted but I have had issues with my logger. The 12V inputs & rpm have died on it. I need to post it back & get it fixed. :)
I guess if the adjustment is on the high speed compression it will only show on the far RHS of the (usually) lower half of the graph. Everything else should stay much the same.
Edited by djr81
It's based on the steering wheel sensor input into the ATTESSA black box. That's why some aftermarket steering wheels make the system go into limp mode as the boss is not compatable.
Hmm, ok. I am more than a little confused. I can find three steering inputs to the HICAS system (left, straight ahead & right) but none into the ETS control unit. (Page CH66 of the manual).
It has 4x wheel speed.
Inputs for the three (2 foreaft & 1 lateral) accelerometers
Stop lamp switch input.
Reverse lamp switch input.
Throttle signal input.
But I cannot find a steering input in the ETS system. :P:D
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
    • Looked it up. It sounds so expensive lmao I'd rather not. Awwwww but I just love that sound
