not a very original sign in... :P ^^^
you know the real DRDRIFT is on here regulary?
Lol, I thought that too!
I'm going for the -9's on my R34 after a lot of reading, previously had 2530's on the R32, but wanted more spread so to speak, and not aiming for 350+kw.
well ive had my number plates DRDRFT for over 10years. plus look at the date i signed up to sau....i aint gonna change it because sam is also known as dr drift....
Seriously though, no beef from me. Was just a thing that stood out, lots or similar user names on here anyways :P
What do we think the -9 is capable of? My GTR is only a daily driven thing so I don't want it running 22psi with 400kw. I was thinking when I get them all installed with injectors etc to suit, to be running a high boost of about 18psi (seems to be a good figure to keep the standard 26 alive) and a low boost setting of 14psi.
14psi= 250rwkw
18psi=280-300rwkw?
If doing mods later and you want more top end, as I plan to, I reckon they really aren't laggy. Then again I had HKS 2530s before so maybe I'm just used to it? I much prefer this kind of delivery to the stockers anyway.
My old GTR which I built 5 years ago had all the normal (saftey not power goodies, forgies etc... and had a set of HKS GTRS, on its maiden tune it made 366.9Awkw @22psi, not laggy.
Lost my licence so sold it but could off got alot more out of it with more tuning.
Now I just got the bug and have just started a new build on another GTR. this time with money being hard, i have opted for -10s, motor has internal saftey work but still running standard fuel system! til i get more money. @10psi i am 300Awkw...this is only stage one and when funds allow will be upgrading fuel system and than start to play again. Not as responsive as previous setup at the moment but not a lag bomb. Anything over 3800rpm and she will start to boogie...I cant make a definitive answer yet til I turn up the boost but so far it feels like even though the -10 is rated the same as the HKS GTRS, I dont think on the street it will preform on par with HKS? But only time will tell....
I think people are too fused about how much boost is safe on the street, It is all to do with tuning, Big turbos doesnt mean lag if setup and tuned right!
My old supra ran 577Rwkw@over 2bar boost, as a daily drive, turbo was bigger than my head and everybody said it will be laggy as hell, but I am also a lazy driver and I can tell you that it was not laggy, no need to drop gears, just excelerate and spin to my hearts content... IMO its all in the tune. Did go to calder just for fun and she pulled [email protected] spin 3/4 track...But that was with full tien drift setup....was not setup for quater...
Dr Drft...
My -10s out performed my previous hks gtrs setup :P
When I built my engine, I was tossing up between the -10s and a t04z and I stuck with -10s for a number of reasons...my tuner told me at the time its either u go -10s or a t51r as he can tune a t51r to come in about 1000rpm later than the -10s so yes I agree with u, tuning plays a huge part in response. Also noted if its tuned for response u sacrifice top end and vice versa.
Although Im running a rwd rb26, Im very happy I decided to go with the -5's rather than the 7's. I have been in a couple of gtr's that are running built motors with the 7's and in my opinion although they are super responsive they seem to run out of steam in the upper rev range.
Using the -5's with poncams and vi-pec on only 14psi my car made 325rwkw easily and pulls as hard at 8 grand as it does at 4 grand with massive amounts of mid-range.
Positive boost is cranking by 2 grand and by 3000rpm its fully into it. After having a RB20 in the car previously this feels like no lag at all.
I realise that once i wind the boost up it will have slightly more lag, but I can deal with that if I can reach the magical 400rwkw whilst still on 98RON.
My 2 cents.
These are the prices I've been quoted for the 2860s. Probably going to go with the -9 for the great medium between the -5 and -7. Also I have no idea why Garrett don't make the -9 and -10 with actuators not included in the bundle.
They did make the "-9" included with actuators.....it is known as the 780371 -1 .... notice the same chra number.
http://www.turbobygarrett.com/turbobygarre...9R_780371_1.htm
I believe your stock act will work as well but i have no idea how they will respond compared to the garretts that come with the new turbo
i guess the clear distinct advantage here is you can keep your working stockers or sell them when you buy a pair of new turbos
whereas if you highflow your old ones, you take them off, send them and get them back later
if price was the same
i would go a new pair %100
instead of highflowing originals
I'm aware that high-flowing something is a little annoying for the mechanic involved, however my point was, as per hypergear's post:
RS has different turbine wheel. Probably not much more in HP, but lot more torque. We've been using those 2x types of CHRAs in our 300zx turbo developments. Very noticeable amount of difference on road, The RS gives stronger pulling sensation while both turbos made within 2KWs difference.
In reference to using a 2860RS core on GTR turbo's. So the extra torque / approx power level is what I'm referring to.
I found a little info on the 300ZX forums but I'm not a member there and they do have 3litre engines.
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
