did u keep your -10's on your sperm whale paul or did u switch to -5's?
The sperm whale is still powered by RS's :spank: BUT I have bought a set of 5's to go on. Who can say no to 1000 RPM less to get to fullboost?
will you get full boost at the same revs as my rb30? should be similar right?
-5's on rb28
-10's on rb30
...will be interesting!
It shall be. With nice and small cams (maybe the mines 252's @ 10.05mm) and 'tickled' -5's. Should be alot better than the choo choo choO chOO cH00 CH00 CHOOF CHOOF CHOOF I have now!
did you ever try running that baffled twin turbo pipe i bought off you? im sure u said no at the time due to the hard pipe kit, you're more than welcome to try it though if u like :)
Your setup should come on boost sooner than mine paul as I had 280 degree cams with 10.8mm lift. My -5s I had on my rb26 was quite responsive, not like my -10s on rb30, but really not far off at all.
You will be happy if that is what you're chasing
It came off my car that night!!!! Lol. It was on my car for years.
  • 6 months later...
why are there so many dyno sheets on here with -5 setups and under 350kw? actually most are around 315kw. from my understanding 350 can be reached with -9's and quicker then the other. Unless there is some sort of other advantage im overlooking?
Would be interesting to see whats supporting mods people have used for a responsive -5 set up. I'm talking 3.5k and on song with 20psi. Even things like short gts4 gear ratios and lightend fly wheel matched with cam timing.
  • 1 year later...
Sorry to be bumping this back up but it has been a very good read. I'm still confused.. Is there a GT2860-9? Or are they listed as a GT2859R-9?? I have been in contact with GCG and they were telling me that the -7 turbos are bigger and have a bigger inlet and will make me more power then the -9.. But this thread has told me other wise.. Please help lol
    • Hi guys looking for a r33 Gtst stock exhaust asap in Melbourne have $$ waiting thanks
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
