Hmm maybe if I go -9's from N1's I can get my 400kw :)
For the price it wouldn't be I guess just to chase 15-20kw..Probably wouldn't even notice it. Will find other ways for further response
HKS V-Cam 2.8 :D
do u have a build thread on your setup as I'm keen to learn more about -9s?
What are u making with these snails?
^Have a friend running GT-SS at 310rwkw @ 18psi (RPM dyno) approx 90-92% inj duty cycle he said. Car has been tracked many times. Fuel system and AFMs are stock.
I have the tendency to go down the same route - retain stock fuel system and AFMs
But I'm concerned about the high injector duty cycle as my car unlike his will see some street and hills use with different temperatures and varying loads.
I also have -9, RPM cam gears, stock dumps, Mine's front pipe, 3" test pipe, 3.5" Tomei Ti catback and PFC.
So all in all, is 90% injector duty considered safe? Accounting for any spikes that may occur.
I know my friend's car is a pretty good example of it's reliability at that level, but would just like some opinions with other guys running -9's who run the car on the street and track as well.
Edited by RB2600
Well what captured my attention is 350kw from -9s...what does it take in terms of boost level and supporting mods to get to this number on 98 as I don't want to run e85?
Hi Nick (levinboy) - what power are u making with your setup?
I'm making 350kw on 98 pump
Full boost at 3800rpm lower depending on weather, 22psi
Built engine still 2.6
Id1000s, Nismo fuel pump
im spinning out - great numbers there on 22psi :)
pm sent
I'd say, once again, attention to detail on the setup is where the better results are. Big, size matched exhausts blah blah.
Got a sheet Nick?
I run -7's with a shitty exhaust and stock afm's. With id1000's and a walbro 400 fuel pump I make 325kw on 20psi with E85. If I fix my exhaust and chuck some bigger afm's on I'd probably crack 350kw.
It'd be much easier to do it with -9's and I don't think there would be much more lag involved.
paul - u should overlay your graph with nicks, i wonder what the difference would be in response & what revs u have full boost
Here is dyno sheet
Tuned for response, hence the drop up top and my cat mainly being restrictive
8A48BB11-9718-4233-9092-94AC91FB0942-568
Will be retuning it soon with new cat soon :)
Ill have a play tonight. Need a calculator and a graph to doodle on.
Fkn speed. Put it in RPM farken!
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
    • Hi. Which coilpacks can i use in my engine? I looked at the Splitfire but the closest "match" i found was SP-DIS-008 but even that they do not show RB20DE NEO so iam not 100% sure. Or maybe different one which will 100% work? I saw many on ebay but they are some cheap "strange" ones. What about Yellow Jackets? Many thanks 🙂
