-7/9s Or -5s Garretts
Adz2332
For the price it wouldn't be I guess just to chase 15-20kw..Probably wouldn't even notice it. Will find other ways for further response
do u have a build thread on your setup as I'm keen to learn more about -9s?
What are u making with these snails?
Tossing up between -5's or -9's mate?
^Have a friend running GT-SS at 310rwkw @ 18psi (RPM dyno) approx 90-92% inj duty cycle he said. Car has been tracked many times. Fuel system and AFMs are stock.
I have the tendency to go down the same route - retain stock fuel system and AFMs
But I'm concerned about the high injector duty cycle as my car unlike his will see some street and hills use with different temperatures and varying loads.
I also have -9, RPM cam gears, stock dumps, Mine's front pipe, 3" test pipe, 3.5" Tomei Ti catback and PFC.
So all in all, is 90% injector duty considered safe? Accounting for any spikes that may occur.
I know my friend's car is a pretty good example of it's reliability at that level, but would just like some opinions with other guys running -9's who run the car on the street and track as well.
Edited by RB2600
Well what captured my attention is 350kw from -9s...what does it take in terms of boost level and supporting mods to get to this number on 98 as I don't want to run e85?
Hi Nick (levinboy) - what power are u making with your setup?
I'm making 350kw on 98 pump
Full boost at 3800rpm lower depending on weather, 22psi
Built engine still 2.6
Id1000s, Nismo fuel pump
im spinning out - great numbers there on 22psi :)
pm sent
Will hopefully have some -9 and E85 results tomorrow :yes:
The old mans car is due out of unigroup tomorrow :whistling:
please share the results - would luv to see some numbers on the outcome :)
pm sent
I'd say, once again, attention to detail on the setup is where the better results are. Big, size matched exhausts blah blah.
Got a sheet Nick?
I run -7's with a shitty exhaust and stock afm's. With id1000's and a walbro 400 fuel pump I make 325kw on 20psi with E85. If I fix my exhaust and chuck some bigger afm's on I'd probably crack 350kw.
It'd be much easier to do it with -9's and I don't think there would be much more lag involved.
paul - u should overlay your graph with nicks, i wonder what the difference would be in response & what revs u have full boost
Here is dyno sheet
Tuned for response, hence the drop up top and my cat mainly being restrictive
8A48BB11-9718-4233-9092-94AC91FB0942-568
Will be retuning it soon with new cat soon :)
Ill have a play tonight. Need a calculator and a graph to doodle on.
Fkn speed. Put it in RPM farken!
