I highly doubt it, or the Gibson 32 would have run a nice aftermarket 3.5 inch system instead of sidepipes.
Hehe :happy: The 34 with the same combo as mine minus cams made similar power and response too my old setup, 2 cars with near identical build, one witha side pipe and mine with a quiet 3inch exhaust! Both running same boost etc initially!
we are not talking about group A race cars mate but street cars, with standard (or very close to standard) capacity 26's with low mounts
and if you were to read correctly, at no point did I mention that the bigger the exhaust the less power - in fact I pretty much said the opposite.
That’s about 60% of the story. The other 40% is why carry around the weight of a full exhaust and mufflers. Why take up space around rear suspension and shafts where you want to run fuel cells and diff/trans coolers.
Why run the risk of a muffler collapsing and hurting power? So introduces need to life components and expense associated with it.
But generally I agree…because ultimately if running side pipes vs full length exhaust hurt power then they would have found a work around. Ultimately the gases before the turbos and immediately after then leave the turbing housing is where most of the battle is fought
Secondly if you are rebuilding your engine put performance cams in it and run -5s. Best all round setup for response and HP in a 26.
Everyone had previously recommended not to go with -5s on a 2.6.. Why do you recommend otherwise?
Have you driven or been in a built, cammed 26 with -5s pushing around 400kws?
Define "performance cams"?
What ever the engine builder recommends for his build. I leave that to the RB masters. As long as the car does what I want it to do, the engine builder can put whatever Cam he wants. All I know is that with standard cams people say it's laggy, but personally I don't mind lag. He he he.
WAITING for aggressive boost is half the fun.
Each to their own, but I couldn't think of anything worse... Waiting for your engine to make some meaningful grunt while a better setup package blasts into the sunset!
I totally agree with you, the rush of boost is awesome!
Although, I sold my GTRS's as full boost was about 5.5krpm which was great for drag racing but not for street.
Having full boost @ 4krpm with -5s and poncams is my next setup...should be achievable :)
If your car is for street use...
-5's make its power towards the top end.
-5's on a stock RB26 would not be as responsive as a set of -7's / -9's.
Hence why people upgrade the cams for better lowdown (2.6lt).
Or people go with a 2.6lt HKS V-Cam / 2.8lt HKS V-Cam or RB28 Stroker.
And since your engine is getting a rebuild it opens you up to all the options.
I personally prefer a responsive RB26 hence why you choosing -9's is a good choice.
Change gears
That won't work in all situations.
You're coming out of a second gear corner at 4000 rpm with a Horrible setup like RS's on a 2.6. You can't tell me you're gonna go back to first!
So you plant your foot and choo choo all the way up the hill, while your mate with -9's blasts past you like you're standing still.
Anyway we are getting into the old forum fight of the definition of laggy setup. Each to their own on this one. I think the best advice is experiencing different setups to see what your happy with. Me personally love the built, cammed, -5 RB26 Setup. Best of both worlds and as my engine builder said, 'the 26s sweet spot'. I drive it daily and love that it's off boost in traffic and starts coming on at a higher rev range. I would hate boost coming on too early. BUT when I want to drive the car then I hold it between 4 and 7-8 and she is a rocket and no lag when it matters. My other car is a HSV LS2 with old school lumpiness and a hi stall. Again in traffic she purrs under stall with low torque to the wheels but when asked to she will flash to 4k and all hell will break loose. Best of both world with both Setups in my opinion.
Change gears
We are talking about -5s on a built and cammed 26 not rs's that won't be at their peak at 4k.
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
    • Hi. Which coilpacks can i use in my engine? I looked at the Splitfire but the closest "match" i found was SP-DIS-008 but even that they do not show RB20DE NEO so iam not 100% sure. Or maybe different one which will 100% work? I saw many on ebay but they are some cheap "strange" ones. What about Yellow Jackets? Many thanks 🙂
