Not likely mate Piggaz 2.8L stroker with all the fruit is probably at around 20psi @ 4K. Full boost on your car would be around 5-5.5K id say.
I'd hope not - my GTRS's were on full song @ 5.5krpm.
When I had -5s, the turbos were getting tickled at about 3.5krpm and pretty were in 'get up and boogy mode'.
Both examples on 2.6ltr.
Sounds about right.
That thing of Paul's is a weapon, and not the average build. It's got ALOT of rnd and tricks, all of which work. A lot of secret squirrel.
yep totally agree with you.
IMO -5s on stock 2.6 will see full boost around 4.5-5K - if you get it earlier than then I want to know.
firstly are you really running 25lb????
secondly if you are, how bout you throw a dyno chart with boost / rpm curve so we can see at what RPM your really making at full boost with -5s....then we will all know.
Edited by Ants
I'd really like to see an overlay of -9s with -5s on a dyno graph.
Does anyone have this info or happy to post their graphs running -9s and another with -5s...from here, we can overlay to see the difference...would put a lot of debate to rest
There is one out at unigroup on the same car. On the dyno, they came on exactly the same but the 5'a made more grunt. However, to drive they were a TOTALLY different car!
What's wrong with running 25 psi Ants? :P
LOL....I was wondering when you were gonna say somethin.......aside from being a ship load of boost nothin really just curious.....about how long an engine would last if predominately driven at that boost level :glare:
Edited by Ants
That is odd Paul. Dyno shows that they huy full boost at same rpm?
Didn't answer the question.. why the doubt? I am offended.
Ill try and get the sheet. Or it could have been the power low end was the same but boost levels were pushed to the right a tad on the 5's.
Leave it with me.
I spose the tune would have a massive part in this. Mine lasted 7 years with anything upto 2.0 bar shoved down it... Only died because the oil pump had a hissy fit.
Mate I watched a built 26 with -5's and poncams on a dyno for a good hour and full boost was by 5000 and it went to 345kw iirc. No chance of getting -5's in by 4 on a 2.6L ;)
  • Like 1
I know Paul.....I know. I'm just conservative and want to have an engine tuned to last as well (I will certainly not push my advance spec beyond 25psi). Your car is insane and would of loved to have a 2.8ltr with similar mods to yours :)
Keen to see those graphs though.
Edited by Ants
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
