I know Paul.....I know. I'm just conservative and want to have an engine tuned to last as well (I will certainly not push my advance spec beyond 25psi). Your car is insane and would of loved to have a 2.8ltr with similar mods to yours :)
Keen to see those graphs though.
Look my dyno sheet is in the dyno section running -5
I'm gonna guess - 337rwkw
That would be a safe-ish figure for a stock RB26.
But personally, I wouldn't push anything past 300 rwkW's on a stock RB26.
Yeah I realise it will let go at some point but why not lean on it a little see how long it holds up.
Making 430KW
Fark!
At the rears?
  • Like 1
Under 300kw on a stock engine would be a good buffer. I was only running 325awkw when it let go. But then again I had a 89 gtr so the engine had a long life.
I see!
Still a big power figure! :D
understatement......I have deep reservations about that engine's longevity at that power / boost level ......I sure as hell would not want to be in the car when she goes BANG!
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
