I only have the 262 11.95 one here the other one is in the states as its theirs and they have the lobe specs, I just trying to get em to put it on a RB stick
Can do. I know Yavuz put the same lobe that's in mine onto a 2JZ stick and doing a back to back, picked up a decent whack of grunt, everywhere over the longer duration "jap" cams. Can't remember the figure, but it was significant.
You know where he is, get it, take it to him, have a chat.
Also thinking about going smaller duration cams but with same 10.8mm lift that current cams are running
Still happy with current setup with the awesome -9s
I don't disagree, Nick. Why do you need a cam that will allow the engine to rev to 10k when the turbos are done by 7500? Smaller duration cams are only going to push your curve to the left, which, for what you do is perfect!
Give me a 245-250 at 11mm plus lift and I'll be all over it. Bugger top end, big fat meaty curve which noses over at 7000-7500. Done! Hard on the valve train but have it looked at every 20-30 k and IF it needs attention, do it.
The jap cams we spun up were very mild in their temp rate, we had two for reference;
Tomei Procam 270 @ 10.25 mm
JUN 264 @ 10.5 mm
Both of which were alot "softer" in their rate of opening the valve than what Yavuz went for. Over discussions he believes that this cam he developed has the same "area" of a larger 280 but without the huge overlap.
This is why we made our own.
I'll see how I go, if I can get my hands on one I'll run over to UE and have a chat
Got my unigroup custom grind cams in today, Same as Paulies.. haven't got the price yet though
Those cams on the supra your talking about made over 400rwkw on gate pressure (a bit over 1 bar from memory) on a precision 6466 I think it was from memory. Yavuz was telling me the other day
Farken 2J.
That is all! :(
JUN 264 @ 10.5 mm
Yep thats what i looking for ..the Piggaz Version 2.0 cams
11mm 252's sound like a winner .. i always tried to find something like the mines super shore pro 10.05 & 252 , but was after some more lift than what the jap stuff usually was.
If that is what your looking for then The ones I trying to get made would be exactly what you want, if I can get enough interest in them I'll see if I can get a group buy going
Less duration then them with more lift
Sounds about right. My -9's (335rwkw) start at 20psi and drop to 18 at redline (8600) with standard cooler. Graphs & info in the RB26 Results thread.
Who tuned yours, can I ask?
Frank at Allsparks in east keilor mate, top bloke, knows his shit about RB engines. Didnt even charge me to sort out a check engine light issue I was having where he found that the pfc had the knock sensor way too low
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
