Are -10's the Garrett GT2871R Ball Bearing Turbos. You guys hav much info about the -10 in terms of when they come on boost, top end power etc? Do many gtrs hav this setup?
Cheers
Unless its on a 3L + I wouldnt go near them. I have RS's (pretty much -10's) on a 2.8 and they will be replaced with a set of -5's. Stupid choof choof turbo's
whats up with the last RB26 dyno post -5's @ 18psi and only 270rwkw ?? sure its pretty much a standard engine, but I had standard engine & standard turbos high flowed making exactly the same power at the same boost ??
theres quite a few others on there @18-19psi making around the 360rwkw mark ? doesn't look right
yeah stock turbos will make 270kw with some cam gear adjustment, 15psi and a good tune (my old car did and still does). still different cars get different results. no way to know what the tune is like, or the supporting mods etc or even how accurate the dyno is. at say 20psi I've seen -5s make between 300kw and 360kw. the mid point of around 330kw is about what they should make at that boost. anything more is gravy. :)
Wouldn't be surprised if they're -9's with a result like that
im glad i got -7's, they are so dam responsive, perfect for a quick street GTR...
my goal was to run around 280 - 300kw with the stock internals, but with sard fuel pump, nismo 600cc injectors, r34 gtr dumps/stainless front pipe/de-cat/3.5" cat back zorst, nistune, greddy cam gears, greddy profec b spec 2
so far only been road tuned on 18psi without cam gears dialed in, getting dyno tuned on the 12th of this month, hopinh for a solid number and a punchy mid range @ 20psi and gears dialed in
will post results in few weeks time :)
  • 4 months later...
read through this whole thread and -9 > -7 from what i can see, also would a gtx3582r with .82 rear be compairable response to a pair of -5's? obviously be light switch power with the 35 but i was wondering if they would come on in a similar rpm.
I know time and time again people say just to buy garrets, HKS isn't worth the mark up.
BUT
would a GT-SS set up have ANY benefit, no matter how small, over a -9 set up ??
Also from my understanding, HKS kit comes with everything you need to install and the -9s are turbos only, would the cost be more comparable after you buy the rest of the necessary items to fit the -9s ?
thanks for any replies :)
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
