-7/9s Or -5s Garretts
Adz2332
For the price it wouldn't be I guess just to chase 15-20kw..Probably wouldn't even notice it. Will find other ways for further response
do u have a build thread on your setup as I'm keen to learn more about -9s?
What are u making with these snails?
Tossing up between -5's or -9's mate?
^Have a friend running GT-SS at 310rwkw @ 18psi (RPM dyno) approx 90-92% inj duty cycle he said. Car has been tracked many times. Fuel system and AFMs are stock.
I have the tendency to go down the same route - retain stock fuel system and AFMs
But I'm concerned about the high injector duty cycle as my car unlike his will see some street and hills use with different temperatures and varying loads.
I also have -9, RPM cam gears, stock dumps, Mine's front pipe, 3" test pipe, 3.5" Tomei Ti catback and PFC.
So all in all, is 90% injector duty considered safe? Accounting for any spikes that may occur.
I know my friend's car is a pretty good example of it's reliability at that level, but would just like some opinions with other guys running -9's who run the car on the street and track as well.
Edited by RB2600
Well what captured my attention is 350kw from -9s...what does it take in terms of boost level and supporting mods to get to this number on 98 as I don't want to run e85?
Hi Nick (levinboy) - what power are u making with your setup?
I'm making 350kw on 98 pump
Full boost at 3800rpm lower depending on weather, 22psi
Built engine still 2.6
Id1000s, Nismo fuel pump
im spinning out - great numbers there on 22psi :)
pm sent
Will hopefully have some -9 and E85 results tomorrow :yes:
The old mans car is due out of unigroup tomorrow :whistling:
please share the results - would luv to see some numbers on the outcome :)
pm sent
I'd say, once again, attention to detail on the setup is where the better results are. Big, size matched exhausts blah blah.
Got a sheet Nick?
I run -7's with a shitty exhaust and stock afm's. With id1000's and a walbro 400 fuel pump I make 325kw on 20psi with E85. If I fix my exhaust and chuck some bigger afm's on I'd probably crack 350kw.
It'd be much easier to do it with -9's and I don't think there would be much more lag involved.
paul - u should overlay your graph with nicks, i wonder what the difference would be in response & what revs u have full boost
Here is dyno sheet
Tuned for response, hence the drop up top and my cat mainly being restrictive
8A48BB11-9718-4233-9092-94AC91FB0942-568
Will be retuning it soon with new cat soon :)
Ill have a play tonight. Need a calculator and a graph to doodle on.
Fkn speed. Put it in RPM farken!
    • So next year I am looking at upgrading from my VE SS bomadore ute to something more refined.  I wanted to stick with a V8 but not anything German or Australian, either a coupe or a sedan. So if I wanted anything newish that limited my options to either the Lexus RCF which I quite like. But with the price they demand and a kid on the way a 2 door coupe is probably not going to be the best idea. The next best thing would be the ISF but the newest models are 2014 and commanding over 60k and even the older 2008 models in ok condition starting around 35k is kind of bullshit. So I figured if I could not have the noise I could perhaps make do with easy power. Enter the infinity Q50 or Skyline equivalent. The price difference between the 300 and 400hp models seems a bit crazy. Right now there is 300hp Q50 one on carsales from a dealer with 61km for 27k drive away. If I wanted to get a 400hp Red or 400R car the prices seem to start at 43k From my limited research it seems that the only differences are that the 400r/Red Red runs more boost and a more aggressive tune. There are are turbine speed sensors on the turbos. Has 2 pumps for the water to air intercooler. Runs an engine oil cooler. I'm guessing that the exterior trims might look a little more sporty as well. I had a lazy look for upgrades to bridge the gap on z1motorsports They have kits that upgrade the water to air heat exchanger as well as the coolant pump which should give a non Red/400r better intercooling temps than the stock Red/400r. I added an engine oil cooler with a thermostat as well to try and make things as close as possible. Obviously the ECU is going to need a tickle. Having not done much in the way of research they also sell a ECU flashing tool with pre loaded tunes that are supposed to boost the non Red/400R by 100hp which adds 1k USD to the cost. The total cost of the parts @ the current time including shipping and taxes worked out to be $4350 AUD. Personally I would rather get the car tuned on a dyno which would probably add more cost Assuming the worst that you got a workshop to install the new parts I would guess no more than 5 hours would be required in the worst case @ 5 x $150 per hour = $750 So the total cost could be around $5100 So for easy number 5k + 27K = 32k I guess that would leave some change left over to swap out the open diff and fit a LSD Any thoughts?
    • Right, not sure why I thought it to be a lean spike. It might be fixable with modern card-style hot film MAFs which have some design features to avoid counting reversion flow but I've never tried it myself.
    • I did not realise this, I'll contribute more and earn my stripes and retry later.
    • I'm only going to hassle you for posting links to images. It's against my policy to click links that could be some nasty payload. Sadly, you need to make 9 more posts before you can just stick the images directly in a post, unless @PranK sees this and bends the rule for you.
    • Hello,new to the group, I bought a R32 from auction recently, wondering if anyone knows the cars history, seems to have the usual go fast bits on it, plan is to do an engine swap- add 2 extra cylinders and 1 extra turbo. https://www.dropbox.com/scl/fi/i4rjmlzubjbwjtguh6f4s/IMG20241011140744.jpg?rlkey=q0lumm251377vknbqktfwrycq&st=7scvwx4e&dl=0 https://www.dropbox.com/scl/fi/ro24qmwzlczzlfsr4y05x/Screenshot_2024-10-10-10-49-23-90_9a2f5bb2149dae94cd1e190effc09b33.jpg?rlkey=oyguh26ttshlf04ccp48odf4v&st=xloae97b&dl=0   New to forums and posting pics, if links don't work, take it easy on me, 42yrs old and I tune carburettors!!
