I only have the 262 11.95 one here the other one is in the states as its theirs and they have the lobe specs, I just trying to get em to put it on a RB stick
Can do. I know Yavuz put the same lobe that's in mine onto a 2JZ stick and doing a back to back, picked up a decent whack of grunt, everywhere over the longer duration "jap" cams. Can't remember the figure, but it was significant.
You know where he is, get it, take it to him, have a chat.
Also thinking about going smaller duration cams but with same 10.8mm lift that current cams are running
Still happy with current setup with the awesome -9s
I don't disagree, Nick. Why do you need a cam that will allow the engine to rev to 10k when the turbos are done by 7500? Smaller duration cams are only going to push your curve to the left, which, for what you do is perfect!
Give me a 245-250 at 11mm plus lift and I'll be all over it. Bugger top end, big fat meaty curve which noses over at 7000-7500. Done! Hard on the valve train but have it looked at every 20-30 k and IF it needs attention, do it.
The jap cams we spun up were very mild in their temp rate, we had two for reference;
Tomei Procam 270 @ 10.25 mm
JUN 264 @ 10.5 mm
Both of which were alot "softer" in their rate of opening the valve than what Yavuz went for. Over discussions he believes that this cam he developed has the same "area" of a larger 280 but without the huge overlap.
This is why we made our own.
I'll see how I go, if I can get my hands on one I'll run over to UE and have a chat
Got my unigroup custom grind cams in today, Same as Paulies.. haven't got the price yet though
Those cams on the supra your talking about made over 400rwkw on gate pressure (a bit over 1 bar from memory) on a precision 6466 I think it was from memory. Yavuz was telling me the other day
Farken 2J.
That is all! :(
JUN 264 @ 10.5 mm
Yep thats what i looking for ..the Piggaz Version 2.0 cams
11mm 252's sound like a winner .. i always tried to find something like the mines super shore pro 10.05 & 252 , but was after some more lift than what the jap stuff usually was.
If that is what your looking for then The ones I trying to get made would be exactly what you want, if I can get enough interest in them I'll see if I can get a group buy going
Less duration then them with more lift
Sounds about right. My -9's (335rwkw) start at 20psi and drop to 18 at redline (8600) with standard cooler. Graphs & info in the RB26 Results thread.
Who tuned yours, can I ask?
Frank at Allsparks in east keilor mate, top bloke, knows his shit about RB engines. Didnt even charge me to sort out a check engine light issue I was having where he found that the pfc had the knock sensor way too low
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
