Hi All,
I saw the other states have their own part borrowing threads but I couldn't see one for NSW. I have been asking and calling around to purchase a stock R33 catback exhaust to clear a defect with no luck. I have tried wreckers and exhaust places for spares but nobody seems to have them. I am now resorting to have to borrow one, and will just have to keep my eyes on one for the future.
Willing to pick up and pay to borrow. Just need for a day (hopefully)
(P.S. If needed, why not make this a borrow thread for future cases)
thanks,
Brian
Edited by bt23
https://www.sau.com.au/forums/topic/254481-wanted-to-borrow/
thanks for the replies guys. i just had a chat to hills and they will get back to me (soon hopefully).
evil_weevil, what's your beer of choice? (need to have a backup option) :)
(P.S. if anyone has a spare around campbelltown/south west sydney that would be even better!)
Edited by bt23
Thought it was you.
Seen you around Ctown. Nice Explosive kit.
I've got a standard dump/front pipe and compliance cat off my Stagea that should fit your R33, and I'm trying to get rid of it.
Details are here: http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=130282861379
Make me an offer, as I just want to get rid of it...
Liverpool Exhaust rent them out. Go chat to Chev.
i called up yesterday and had a chat to one of them, if they their hands on one during they week they will let me know (they said they just chuck them out now)
Thought it was you.
thanks dude, pm me or link me to some of your pics, im sure i would have seen yours around the area too!
can anyone confirm that this actually fits an R33? i don't want to try something out that might or might not work out so well. (plus i am going after getting the muffler replaced as its the baffle/gurgle noise when revving down causing the defect which i think the muffler is to blame. please correct me if i'm wrong)
No worries mate, drop me a pm if Im the last resort!
Chang beer is good, BWS has them for just under 40 bucks :) heheh
Im located north Sydney - Lane Cove :D
sounds like my best option so far if none of the exhaust places get back to me. i work in north sydney so maybe i can drive to work one day if nothing can be arranged on a weekend.
Just throwing some thoughts i still got my standard catback exhaust of my r33 but dont know if series 1 can fit series 2.... anyway i got RB25 engine... if you want to borrow them let me know im from ST ANDREWS... (how much $$$$ for borrowing? lol and how long you gonna need it?)
No dramas, let me know as early as possible, as its actually at Mum and Dads in Hornsby
:yes:
ill let you know asap, hopefully by tomorrow night (want to check out the pbk1776's as he lives 10 mins away). thanks for your help so far
Just throwing some thoughts i still got my standard catback exhaust of my r33 but dont know if series 1 can fit series 2.... anyway i got RB25 engine... if you want to borrow them let me know im from ST ANDREWS... (how much $$ for borrowing? lol and how long you gonna need it?)
series 1 exhaust should be the same. st andrews would be ideal to pick up from, PM sent. any chance i can see this tomorrow arvo around 6pm? PM sent
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
