Item 1:
Garrett GENUINE GT35/40, still in its garrett box
Ball Bearing
0.82 A/R rear
0.7 A/R Front
T3 inlet flange
has not been on an engine, ie NEW!
Price: 1680
Item 2:
Billet 80mm Throttle body
Adjustable idle control on spring loaded pulley
Colour is Blue
Brass butterfly
has not been fitted - NEW!
Price: 220
Item 3:
Rb25 4mm thick steampipe manifold,
Superbly made by Kelway (member on this forum)
Its Silica Coated in black
Has a 44mm outlet next to collector for Tial 44 Gate
Has been machined flat on T3 flange and exhaust outlets
Price: 650
Item 4:
Tial 44mm Wastegate
Item was used for 2 dyno runs, taken off due to being overkill
As New
Price: 490
Pics will be up later, somewhat negotiable.
Contact me (Slav) on 0401689894 or PM, SMS preferred, much quicker than pm, coz i dont sit at the computer all day
From?
i assume you meant location, its in WA, pics to follow, have pic of TB n manifold, turbo and wastegate, well u know what they look like, turbo brand new and WG as new, used for 2 dyno pulls
OK, i've finally decided, my project is destined for the too hard basket
so for sale i also have the following
RB25 S II HKS intake and exhaust cams (256 deg / 264 deg)
RB25 Greddy intake plenum, its a copy but has been refined
RB25 HKS adjustable cam gears
RB25 Complete Head which all the bolt ons were going to be setup on
Tomei Type A springs
Bronze Valve Guides for RB25 head
RB25 Water Pump
I will do everything Listed here and the turbo, throttle body, exhaust manifold and wastegate for $6000 delivered. I do not want to separate all this, as doing so will leave me with loose parts for ages. so there u go, if u want a guaranteed 500HP head package, its all urs for a measly 6k. this was going on a built rb30, which would have a lazy 550hp at the treads on low boost. Do your sums, add it all up and find a better deal.
Slav
when u do eventually decide to seperate pending price ill take the plenum if someone can confirm it will fit 34neo motor with no hassles
  • 2 months later...
    • Haha watch Alex's eye twitch when you mention Nistune to him in person lol. He's not a fan, then again it's quite a niche product. I personally don't mind them, but most usually steer clear from it. Word of advice, do not ground the AFM to the chassis, there are heaps of incorrect guides on the interwebs. Send both GND on the AFM back to Sensor GND on the harness.
    • Note I edited my post, so Sleeper's quote is not the same as what I meant any more.
    • That's a whole 'nother issue. Nissan ones get dirty and sticky. The coolant heats the wax pellet thingo to close the valve, so it is open when it is cold. And so if there is no coolant it just takes longer to close, because the heat has to soak all the through the inlet manifold.
    • I feel like this is crazy pills though. Isn't it locked up all the time anyway? It shouldn't flare anywhere if it only unlocks momentarily while it shifts gears. And if it flares like that when shifting gears, then the 8HP with a 5500 stall is not driving as well when on the road and/or track use..
