http://www.datsunrestore.com/h4_bright_white_kit.html
this way you can use any bulb you want and you can get that VIP lexus look with your lights.. well that was my dream anyway and now it's possible!
https://www.sau.com.au/forums/topic/254500-thought-these-were-quite-clever/
just gunna ring the guys first and make sure Australia delivery is all cool and if so, make sure the two different pairs are put in the same shipment.
that would save me a few bucks in shipping no??
but yes im gunna get some.. as i think it would look the sex...
I'm confused. What's so special about these? They're a standard semi sealed kit, no?
I fitted these to my 180B over 20 years ago. Hardly anything new there.
You can buy the same from Hella, Narva, Supa cheap or just about any car accessories shop in Australia.
By the time you convert the $$ and pay postage, you will get good quality stuff here in Oz with a warranty.
Dude at Ausrotary selling kits here: http://www.ausrotary.com/viewtopic.php?f=48&t=139477
Edited by warps
grabbing some off this lad. thanks for the link!
Yep - Simon's a good fellow. He knows his auto electrics - has provided lots of valuable info over the years. He's written some excellent tech posts on setting up thermo fans, relocating batteries to the boot, and upgrading alternators (although the alt upgrades are Mazda specific).
You might find that you have to upgrade the wiring to your lights as well. I dare say that the (cheap) original wiring in your Dat won't be up to the task ,and have some massive losses. Running new wiring with relays, and proper battery feed will make even the standard sealed beam candles much brighter.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
