This is a list I found on skylinesdownunder regarding R33 paint colors:
AN0 Super Clear Red
BN6 Beep Marine Blue
KH3 Black
KL0 Spark Silver
KN6 Dark Grey
LP2 Midnight Purple
QM1 White
KP4 Sonic Silver
AR1 Super Clear Red 2
Does anyone here have a Silver or Grey R33 that they have pictures of, so I can compare and determine what color mine is (it's on a dock in .jp and the supplier can't get to it to tell me).
I'm looking for KL0, KN6 and KP4 colored R33s.
Thanks,
Jason.
https://www.sau.com.au/forums/topic/25453-r33-paint-colors/
Yeah, this is the info from http://meggala.com/r33option.html :
The SII R33 range came in 6 standard colours (not sure on the GTR?) I even have the paint codes
White - QM1
Red - AR1
Black - KH3
Blue - BN6
What looks like Graphite - KN6
& Silver - KR4
I dunno' what the actual Nissan names are for these colours, cause I can't read Japanese I don't have the paint info for the SI range
I've confirmed two people who have the KR4 paint, and I'm hoping the R33 I've just paid for is the same!
https://www.sau.com.au/forums/topic/25453-r33-paint-colors/#findComment-540861
Apparently it has some hks gauges (the guy could tell from the photo) and that was it.
Although, looking at the rear end photo, it does look like its had a non-standard zhorst fitted. I was told that it only had the rims and gauges originally .. will just have to wait and see!
https://www.sau.com.au/forums/topic/25453-r33-paint-colors/#findComment-541008
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
