I would have gone for a dual plane element version had one popped up, but as I wasn't about to spend $2500 plus on a wing I took what was available in the right sort of sizing for the car, in excellent condition. Most wings were too small. I was also quite set on either the C-West or Voltex as I wanted something proven, and the Voltex popped up first.
I actually used to have a dual plane C-West but in aluminium. I was defected my first week of having it on so I got rid of it! It was also a bit heavy, noisy and not wide enough.
With the correct front bar with dive planes, mated to a nice undetray, chopped rear bar with diffuser I think it would make meaningful gains in cornering force - but what do I know! :whistling:
Something like this:
  • Replies 105
my car is alot more well behaved now with the wing on, most noticably under heavy braking.
i got this gt style one a while ago now, but after reading info off this thread.
as stated by others, a wing is a bandaid for other setup issues sometimes, best to develope suspension before adding wing.
if only i listened to that advise lol.
What width and height Adz? I am expecting that the R34 GTR wing I am running to be inferior to a wing like yours...so doing a bit of homework in case i need to buy something.
In regard to height, with my very limited knowledge of airflow over the roof of a car a rear wing should be level (or close to) with the roof line in order to use this airflow. Adz's above looks perfect.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
