Awhile ago my mechanic retarded my timing slightly when tuning the S-AFC. That's done with the little metal thing with the 3 bolts in front of the exhaust cam right? Anyway I don't know what it was before or after, and before I install my PowerFC I want to set it back to what it should be (factory settings? someone advise of a better setting for 98RON fuel if not)
So my questions are - (1) Is the timing set with that metal thing I described above? and (2) What should I set it to? I guess I can also throw in (3) Where are the timing marks and where do I hook up the timing light? I should be able to work it out, but on the off-chance it's confusing then someone please tell me :P
This being for a '95 R33 GTS-t.
https://www.sau.com.au/forums/topic/25455-powerfc-and-timing/
Stock timing on a R33 GTS-t is 15 degrees BTDC.
The timing marks are on one of the pulleys on the front of the motor, you should be able to see the plate that has the 0-5-10-15 stuff on it down there somewhere :)
I'm just guessing, but if your going for a PFC, set the base timing on the CAS at stock (15) and then get your tuner to tune the timing via the PFC.
J
Thanks Jay!
I'm going to get it properly tuned, but I plan on trying some road tuning myself. I've got a map based on a setup similar to mine, so I might try setting it up somewhat more conservatively than that and get my mechanic to fine tune it afterwards.
Oh yeah, does anyone know where to hook up the timing gun? Normally you put it on number 1 spark plug lead, but this car got no leads :)
Cool - sounds good. The hand controler has got a knock readout, so that should keep you out of trouble :mad:
The pickup for the timing light is right at the back of the motor where the ignitor module is (if you've got a series 2 motor it's still up the back there), and you'll find a loop of white wire just hanging around doing nothing.
The look is only just big enough to clip a timing light pick up through.
The wire might be hidden under some electrical tape.
I found that the standard (cheap :) ) timing lights aren't sensitive enough to work off of this pick up :) But give it a try, it might work with yours.
Cheers
J
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
