Hi,
I have some extruded mesh to suit front bars available, it has larger than your normal mesh hole, to allow better air flow while still keeping birds, rocks and small kids from your intercooler or cold air duct.
Mesh hole size is approx 10mm x 5mm.
I had to buy a whole sheet to get some for my front bar, so I now have alot left over.
If anybody is looking for mesh in Adelaide, contact me:)
Cheers
Steve
Well for a piece 1.2m wide by 0.5m high, enough for a front bar and some left over, about $40 - I am not making any profit on this, just trying to cut my losses having to buy such a large sheet:).
My front bar is designed to have mesh attached, some use wire fiberglassed around the hole on the inside of the bar and you just put the mesh over the wire and bend it into place - others already have screw type attachment from behind.
But you can also use body filler (bog) to attach it as it sets like concrete or you could use sikaflex - no way that will come off by itself.
