For sale: TURBO BLANKET-BAG-BEANIE ETC..
Item Condition: NEW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Price and price conditions: $220.00
Extra Info: Suit T88's, T51's, T04Z, GT40, T78, T66, T04S
They are made up of heat resistant polyurethane/silicon coated fibreglass cloth, with an inner of 25mm Heat Absorbing Ceramic material, and a stainless wire mesh to retain the "wool". The Ceramic Wool is space age technology material with tolerences in excess of 1000 degrees C before mechanical breakdown of the material.
The Blanket is designed to retain the heat in the turbo, reducing the loss of energy/heat from the turbo. This intern gives the turbo earlier spooling and greater horsepower potential. Back to Back Dyno Testing verifies a performance increase from fitting the blanket. Not to mention the cosmetic benifits of reduced temeratures within the engine bay! No more burn't paintwork and cooked wiring looms etc.
Pictures:
Contact Details: 0405 525 689
Delivery & Conditions of Delivery: PICK UP, Or delivered at buyers expense
https://www.sau.com.au/forums/topic/254573-fs-turbo-blanket-bag-beanie-etc/
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
