well I can help you out for a start, I have to complete hub assemblies from an R33 that you can have for 250 for the pair (want to sell them together), i'm sure a few others will have some spare parts in there shed that they don;t want and you'll be on the road for under $1000 because once you have all the parts the rest is just bolts.
ok, but u did say control arms, hence why it was all over the place, especially considering S13's dont have upper control arms at the front, only at the rear.
and remember, S13's and R33's both have completely different front suspension.
Yeah that's fair enough, wasn't meaning to be rude!
But yeah R33's & S13's are completely different.
control arm most likely... mine is bent too from previous accident, wore out the tie rod end as if wasnt fixed in ages. im looking at fixing it atm, the wheel is a couple cm off and you can clearly see underneath the car if its much bent compared to the other side.
Seems like a simple enough job to replace, could probably do it at home, not in this weather tho... been putting the car off for a week now :S
That looks very similar to mine Bezender. The wheel is pushed back but not as close to the gaurd as yours. Well i'm taking my car into a place monday morning to get a second opinion so i got my fingers crossed. Wasn't expecting so many replies to this haha. This weather is f**ked im prob gonna just pay up if this quote is cheaper than the last, i need my car back so bad to get to work next week.
hmm nisskid if its the lower control arm its like 250 for a second hand one good luck getting out of it that cheap.
dunno who ur buying from but if ur paying anywhere near $250 ur getting ripped off big time.
saying that, i just remembered it is a R33 not a R32, and the R33 LCA's are in a bit more demand and cost a bit more, so might be a bit more but still no where near $250.
i still marvel at how people on SAU seem to get ripped off so much :P
    • Nice. I'm looking forward to the updates!
    • Ayooo, been a while mates. I have a s2 r33 gtst and air stopped coming out of all the top vents.   My car has always made an actuator gear noise when turning the car on but that's a different issue I think? Did searches and am at process of thinking it's an actuator or some type of motor? I see a few different actuators and don't know which one. Would be nice to know if it was the one that's under the steering wheel so the dash doesn't need to come out.
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
