  • Replies 81
Agreed, Aquagolf will be the new spot from now on. Distancing ourselves from all the wank stains who think doin' skids in their mum's single spinner is a good plan.
there's a reason we don't usually meet at KK's. I haven't been down there for ages and last night reminded why.
- - - - - AQUAGOLF CAR PARK IF THERE IS A MEET NEXT WEEK. - - - -
Why not meet away from the crap house that is panthers and go somewhere more secluded and less likely for cop trouble..
For instance, further down mulgoa road either direction is a bunnings with a big car park.
Jamison park, just up the round 'a' bout from panthers.
If it wasnt a thursday night could even do it on a certain lvl of the plaza carpark away from the cinemas, just dont be hectic habbib and get securitys attention.
Just my two cents.
plus i cant get into aqua golf with my front bar from memory
AQUAGOLF CAR PARK @ 8ish
If you think it will be hard to contain yourself and drive sensibly around the meet spot don't come. Or go park around at KK's where you'll be able to impress the 15 year olds and blow ins.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
