Hey guys, Just wondering if anyone is able to help me out with camber issues for my brothers s2 rs4.
The car is currently running -3.5 at the rear and is quickly scrubbing tyres. Due to needing so much adjustment will I get away with just a camber arm or will this mess up the rear toe? From what I can see the rear toe is not adjustable as it is non hicas so as I said I am to think the toe will be stuffed. I know he will have to run an arm appossed to the camber bushes as there would not be enough adjustment and the arm is cheaper.
Any help is greatly appreciated as Im lost, haha.
Here is a print out of his last alignment as previously posted>>> http://www.skylinesaustralia.com/forums/po...nment-200808291
https://www.sau.com.au/forums/topic/254700-s2-rs4-suspention-dramas/
Mate, the rear toe is adjustable from factory. Depending on where it is currently set, you may not need to get adjustable rear toe arms.
check out this thread...DIY Fitting adjustable rear camber arms
I had similar issues as your bro. I just fitted adjustable camber arms and corrected the toe, using the stock toe arms, to give me good rear camber figures without excessive rear toe!
Good luck.
I used Monsta Performance adjustable arms from E-Bay, cheapest around plus come with 1yr warranty. If you search through all the pictures in the listings for the different suppliers... its pretty easy to tell that about 80% of them use exactly the same arms, they just paint them different colours!
When you go for your alignment, make sure you specify that you want to get as close to -0.5deg camber on the rears whilst still keeping ~0mm toe. They may not be able to give you the full -0.5deg camber (esp when you are starting from such a high neg camber), but it is more important that they don't give you heaps of +ve rear toe.
-1deg camber is still quite acceptable, but you may need to flip your tyres on your rims halfway through their life (only if they are symmetrical tread pattern of course) to get good wear across the tread and good tyre life.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
