Hi all,
Just bought some new wheels. :)
The are 19x8.5 front and 19x9.5 rear.
On the rear i am fitting 265's and know i need lip the gaurds on my 32.
Just wondering if people know of a good place in melbourne to do this..... and also what its worth to do?
Any info i really appreciate.
Once rims are on ill be posting pics =)
https://www.sau.com.au/forums/topic/254706-new-wheels-lipped-gaurds/
how easy do the guards "flare" on an r32 gtst??
im undecided as to get some nice rims that dont fit, and make them fit, or just get different rims later.
ive found some awesome rims that look phat on the car, and most importantly, they are the right price, from what the importer can tell they are 17x8 and 17x9, but the 255s on the rears fit too well, so im thinkin they might be a 9.5" and 8.5"
the rears, with the car still jacked up, the edge of the rim was almost an inch out from the body.. the top of the tyre was about 15mm out.. but with a stretched 235 tyre it will come close, so some slight flairing will be needed.. im just worried that the rim itself will still be sticking out too far to look any good
the fronts stuck out a bit, but not an issue, ill just fit some wider guards or something but the fronts didnt have tyres on so i couldnt drop it down to check fitment properly.
i might go back and just put a rear on and see what happens.. my car is pretty low and has lots of rear camber at the moment so hmm...
the rims in question are Panasport GT's and suit my 32 really well.
so do i get them and flare the guards to suit?? or just not get them?
cheers
Linton
Edited by NZM.031
look at the wheel and on the inside will be the size and offset...
from this someone will be able to tell you how it will fit on a 32gtst
15mm out and stretched tyres should fit fine....
i'm running 18 x 9.5 +30 and it sits around 10mm out if my guards, and i deff have room for another 5mm i also have near flat camber and the car is slammed pretty far. i run 235's
i checked for a sticker or any sign of an indication of offset or size.. nothing there... the shop annoyed me and when i got the wheel on and saw instantly that it didnt fit, i cracked it and didnt really have a good look i guess. my bad.
Hi all,
Just bought some new wheels. :D
do you know the offset of those wheels?
i think 265 /19 will be too much for gtst guards , unless it has like +40 offset?
hey Excess...
They are plus 38 offset.
When i spoke to the dealer he said they would fit but might need to tuck the gaurds / lip the gaurd a little bit jut to make sure.
Im going to wait till the wheels get here on Monday and try them then see if i need to.
Was just curious, im sure people have had this done before and was wondering a good place to get them done. (around melb)
hmm being 19" its most likely you'll have to roll. with a +38 offset you might not have to lip unless ur car is super low. i think 265 might be a little over kill if you want to really tuck them in. run 245 or 255.
cheers
Linton
Did you even take the car off the jack? Once you do the the wheels will camber inwards and might fit without, or just lip the guards.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
