  • Replies 138
?? NISMO - Nissan Motor Sport OEM supplier, so direct fit for R34GT-T.
I'm not trying to pedal anything, just saying that that bloke made a mistake when he said that R34 NISMO injectors were 440cc that's all.
I'm not trying jam them down anyones throat, just trying to help out with some options. :)
Fair call, I'm just trying to figure out if there is a larger equivalent that came factory fitted to another engine. I can't justify near on $1k for an extra 100cc's for my daily :)
Deutschworks?
Does anyone know how big 350Z injectors are? being a 3.5L engine I'm hopinh they're bigger than 370cc..
From memory they're about 300cc....not big at all, as some zed people are using the R34 Blue 370's as upgrades.
I've been more than happy with the deatschwerks injectors, I've got the obsolete 550's the newer 600's replaced them on their site last year, they're 100% drop-ins
I remember asking the question about the XR6T injectors a while back, never actually found out though :)
480cc'S can go more then 242 kws cant they
from memory i pulled 215 from stocko ones would 100cc really be only 30kws more
(oh mines currently at 244Kws (have run 248Kws) with nismos and I could have sworn they were not maxing out yet )
Well my stag is making nearly 240awkw on stockers, they were pretty much maxed at ~260awkw and there was still a few psi left in the turbo which is why I'm looking for something a little bit larger :)
Edited by bubba
ok, blitz made good ones but discontinued, so pretty much forget about those. One wrecker i think in SA has some second hand ones but for about $1200
Nismo are the ONLY drop in ones, 4 hole spray pattern, $1200-$1300 delivered, stupidly expensive and rare as hens teeth to find second hand, trust me, i was looking for a while until a set turned up on ebay. And what do you know, someone on SAU is selling a set :banana:
Sard aren't straight drop in like the Nismo's, and frankly, don't have that brilliant a rep compared to the Nismo's.
Other options then become...
GTR injectors (need fuel rail and possibly resistor packs)
HKS fuel rail which gives you more options
Hi flows - done here locally or done via deutchworks, some people love them, some people hate them. RC Engineering in the states could probably also rustle up some hi-flows.
Then, i was going to go with ANOTHER option until i found the Nismo's. A guy in Melbourne was advertising converting side feed to top feed, using these billet aluminium bungs or something. I asked if he could go the OTHER way, top feed to side feed. Because if us NEO'ers went to side feed we'd have a ZILLION options. He doesn't see why you couldn't go top to side, but i never followed through with it cos i found the Nismo's.
I know there's no OEM info, but that's pretty much what i found out with after market options for the NEO, and yes it's VERY limited if you don't want hi-flows or get fiddly with new fuel rails.
I reckon someone should give the top-side feed conversion a shot, cos surely then there would be a lot more options available.
I had actually toyed with the idea of putting the R33 inlet runners on the Neo head and just using R33 side feeds on the stock rail....but I never got around to confirming the stud patterns matched up, anyone care to check it out?
Yeah thats the one, i got them ones highflowed to 555cc.
You had 350Z injectors hiflowed?
Also, anyone know if a 26 fuel rail will bolt up to the intake manifold? or could be made to bolt up? a fuel rail is just a fuel rail afterall.. and being able to use GTR injectors means I could then also use hand-me-downs from my 30!
Edited by bubba
  • 3 weeks later...
Hey ppl's I'm still working on this little project. just waiting on a bit of cashola to come through.
can any 1 confirm if Neo Rb25 heads have the same injector spacing and mounting positions as a non NEO RB25 head?
also do R33's run the same style stock FPR. as i want to retain the stock FPR?
regards
Chris
you are a dingis . have you not read anything about this sublect at all ?
You sir are a Dingis for using the word Dingis. LOL
I am very confused at why u think this is such a stupid non thought out project.
Was it the part where I'm going to use cheap common injectors or the part were i asked if Neo and non Neo's had the same spacing between injectors.
Whether they be top feed or side feed is irrelevant.
Please explain where I have gone very very wrong?
regards
Chris
Edited by urtwhistle
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
