  • Replies 138
Been seeing ebay list injectors for R34, and XR6???
"SIEMENS 550CC FUEL INJECTORS LS2 R34 SKYLINE XR6 TURBO
SET OF 8 DIRECT FIT LS2, LS3, SKYLINE R34, FG XR6 TURBO
Feedback: 3,060 | 99.8%
Watch this item"
http://shop.ebay.com.au/?_from=R40&_tr...-All-Categories
Someone say SHIT YEAH! :)
im looking like crazy for injectors and still finding it mearly impossible to find a set for a decent price.
not looking for more then 480 or higher then 550cc.
any updates!
Std Subaru Sti injectors are 550cc @3bar (they are pink) they will drop straight in. This is an OEM part - so really really good spray pattern and low frequency control. There are a few companies that high flow them to 650cc @3bar which I've used on a couple of WRX's and they were very nice to tune on the factory ECU.
PS the EV6(xr6 turbo injector style) and EV14(LS2) are 14mm compared to the 11mm denso parts used in the subarus and other denso based ECU's.
PPS 550cc injectors should support around 330-340rwkw.
Edited by rob82
bah, all these options coming out..
i have a set of Nismo 480cc if anyone wants them, shoot me a PM. 4 hole spray patter, nice atomisation (none of that sard crap) and DEFINITELY a straight drop in. Should see ya to 300rwkw without drama's :thumbsup:
Great news! ... But don't the Sti Injectors cost alot more? Can't remember what my WRX mate paid for his.. but it was quite alot, and that was just for four! lol
  • 3 weeks later...
the sti pink tops are 11mm? arn't the r34 top feed's 14mm? any news on these FG Falcon top feeds? or has anyone bought these injectors off the ebay seller?
hey Hopeyz, yes the R34 injectors are 14mm,
yes i do have the XR6T injectors but no i got mine off the Xr6T forums.
only last weekend I installed these injectors. It was quite frustrating, but worth the $600 saving, although the car has not been tuned as of yet.
If any 1 follows part or all of what i suggest dont blame me if you catch fire/mame you or any 1 else etc etc etc
things you will need-
3 off packs of bosch plugs (2 in each pack) ACA brand p/n BK402 $13.00 Trade per pack pack
2 off spacers 20MM (wide) 12MM (thick) with a hole drilled 8.5MM $free I have access to a lathe
2 of M8x30 bolts free out of the bolt rack
1M 5/16 EFI hose $10.00
2x hose clamps to suith 5/16 hose
1x throttle body gasket (not needed if you don't break the 1 that is fitted) nissan P/N 16175-31U01
1x AAC valve gasket (not needed if you don't break the 1 that is fitted) nissan P/N 23785-AA001
1x "water connector" to remove air from cooling system. (mine was corroded closed) nissan FAST P/N 14875PB
1x tube of PBR rubber grease for O-rings
lots of spanners screw drivers, skin on nuckels, soldering iron, heat shrink, pipe cutter, pipe flarer
and most of all a huge amount of patience.
a few key points cos i never took photo's. hind sight is a great thing.
first thing remove items in marked in RED
ie throttle body, strut brace, AAC valve, enginer cover bracket, FMIC fan cross over pipe and water connector.
under the blue x's you will find things that if you unbolt now you will find it alot easier later on.
ie the feed side of the fuel pressure regulator 2 10MM bolts from memory.
Below the AAC valve attached to the side of the head is small bracket that has the wireing loom atttached to it. remove as it will foul on the fuel rail when you try and fit with longer injectors.
next to the oil cap ( you can see it when the engine cover bracket is off) remove this bracket as it only makes removing/fitting the rail harder.
get rid of any fuel pressure in the lines (if you don't know how to do this already, put your car back together and pay some 1 to fit Nismo's)
remove feed side rubber hose from fuel rail (short hose at the rear of the fuel rail) just chop it with a knife and watch half a litre of fuel drain on your nice shed floor. its too dam hard and stiff to try and remove when fitted.
unbolt fuel rail and lever up square, remove injectors first.
remove fuel rail (lift up front end of rail at 45deg to motor and wiggle its way out)
clean injector holes in manifold carefully ( i used a peice of copper pipe with the end flared to a tight fit on the machined o ring face. then blasted away with the air compresser) a peiced of sharp dowle to block the hole would also work.
now using the dodgy FAST screen dump.
now get your fuel rail and chop the center hose mounting tab off with the angle grinder(marked in red). (it fowls on the intake plenum when trying to fit injectors)
the steel hard lines attached to rail marked in yellow need to be carefully bent back square with the rail ( you will see when trial fitting with an injector fitted, you will not be able to get the rail on the injector as the pipes will now hit the intake)
cut the steel pipe marked in blue just after the 90 deg bend. put a flare on end of tube.
use rubber grease slide efie tube around the elbow and put pipe clamp on (allows you to do it up away from the intake.) measure hose to the end of the fuel rail and cut to length replacing the stock small efi hose you cut earlier.
solder on new injector plugs.
put rubber grease on injector o rings and if all goes well you should be able to test fit the rail with your next injectors.
I found putting the rail in and pushing 1 cm towards the firewall allowed me to fit the injectors and pull back towards the front and its should just drop in ontop of the injectors.
then if thats all good bolt it all down with the spacers and get it retuned.
there was alot of little things that gave me the shits along the way but the main things were spring clamps snapping and hoses going hard/ deteriating.
best of luck to the next person.
Chris
so you getting the car towed to a tuner now?
more then likely will set the fuel injector to like 50 % in the power FC and let it get warm enough that can reset it to stock then drive it there on LPG. the gas convertor has a sensor in it that wont let it switch over untill the water temp is at 40 deg or there abouts.
I called them today and got a quote and was told $1020 for 6x injectors plus plugs and spacers.
they are located in victoria and delivery to sydney is an extra $14.00
they come in to sizes 570cc and 630cc. both the same price.
they branded by siemens.
personally speaking for i would go the deatchwerks injectors which are straightfitment and direct replacement for $850 delivered to australia and are made from denso parts.
although like i said before i will let you all know how they go once i install them but i have heard nothing but great things about them from other sau'ers.
hey
where did u find deatschwerks for $850 to australia? do they have any dealers / distributors in australia?
i'm looking for their 600cc for my neo.
cheers.
hey just thought id post my latest experiences with r34 injectors on here without starting a new thread so here goes...
got a set of 660 cc (could be 630 not 100% sure... anywho) siemens injectors from unigroup engineering apparently they are for the xr6 turbos so i gether they are the same ones you guys are refering to on here... yavus told me they wouldn't be a straight fit and i needed to make up some 9mm spacers... knocked up a set on the lathe at work and wallah... everything fits, nothing fouls and unigroup engineering said that they have a good spray pattern... i havent got the car tuned yet but as far as i know everything seems to be in good order... i paid about 140 each i think with plugs its a heck of alot cheaper than paying up to 200 per injector and you have some money left over for the better things in life like drinking beer :blink:
damn dude you should have gone in the group buys on the xr6Turbo forums. min were closer to about $80 each with plugs.
did you take the top half of your intake off to fit? in retrospect i think that would have been alot easier and i wouldn't have had to cut and bend the pipes.
i got mine installed and running the other day. but every time we loaded the car up on the dyno for some reason the injectors randomly cut power for a split second then turn back on. a sensor was put on the wiring too. It's odd. i can free rev the motor and drive the car around fine. I have since soldered in 2.8 Ohm resisters to bring it up close to the stock resistance. I am not sure if the power FC injector drivers were over heating or something in my Prins gas ecu freaking out.
since doing this it does appear to be running a bit nicer esp when its hot. i towed my father in his navarra dragging the breaks at 4k rpm at 10psi and i couldn't get it to fault like it was. So here's hoping i don't need to pay for more dyno time to find out the problem is something else.
it will be interesting to hear if your car tunes perfectly the first time space goat.
Also just for any 1 wondering the injectors have been set to 54% +0.16MS Lag
Chris
P.S i just noticed you mentioned 9mm spacers. did they bolt down fine on that? now im curious if the injector is sitting too far out on mine. although i don't have any fuel leaks with using the 13mm spacers.
Edited by urtwhistle
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
