  • Replies 138
yeah i read all that cheers, signed up to the ford forums now so having a read thro it all.
whats the diff between the BA-BF deka's and the FG deka's? and which one do i need for the neo.
cheers
i have no idea about FG falcons................ seimens injectors are used as an upgrede not stock. ie Siemens have branded this injector DEKA. if you find any thing has changed let me know.
Well, thanks to urtwhistle for his hospitality yesterday, it seems all I have to do to fit my RB20 injectors (same would go for GTR injectors I guess), is machine the bosses down a bit on the manifold where the fuel rail bolts and change the manifold side o-rings on the injectors.
Actually.. just had a thought.. Chris, what length are those spacers you are using? I only checked against your seimens injectors and forgot you were spacing the rail.. if that's the case then I'll probably just need a smaller spacer (couple of washers) instead of machining the bosses on the manifold down..
yeah i got that much cheers. So you ran the BA-BF replacement deka's then im guessing? as theres two diff part numbers (and prices) for the BA-BF and FG series.
Sorry mate if i came across a little abrupt, i was just feeling a little frustrated at the time. (was agro cos i lost a 10mm socket for a few hours)
oh i see i never realised there could have been a difference. Yes i went BA turbo injectors. siemens/VDO p/n FI114961
No problems, your welcome to drop past any time. its good being able to put a face to the name. I'm currently using a 12mm spacer.
you may be able to use some gr10.9 washers as they tend to be a fair bit thicker then engineering washers. give me a yell if you run into any trouble. i may have some in the bolt rack at work.
regards
Chris
if anybody wants a cheap set of the 80Lb (875cc) Dekas, ive got some for sale here (new).
http://www.skylinesaustralia.com/forums/wa...87#entry4806887
Ok i'm interested in these injecters.
I have read the whole thread but most of it relates to the rb25 fuel rail.
Now what do I have to do to make these fit? 23MM spacer with a longer bolt and longer fuel hose? Just so the fuel rail sits abit higher up?
hey fella, i have no idea about RB26's but yes i stated [b]13MM[/b] I ended up grinding them back to about 11MM as there was a bit of extra play there that i didnt like.
and being a GTR you probly dont need to worry about the fuel hose. But thats somehting you might need to look into.
So the fuel rail just has to sit higher? Thats it? The injecters that I looked at are top feed as well.
exactly and change the injector plugs to suit. but due to it sitting higher you either have to mod the rail so you can actually get the rail on the injectors.
or take the top half of the plenum off install the injectors and rail un modified. as the rail only clashs when your posittioning the rail over the injectors.
What cc are stock Z33 injectors? Are they a great bolt on upgrade for the ER34?
To my knowledge there the same style but unsure of the stock CC. i highly doubt that they would put bigger injectors in a NA car though.
regards
Chris
  • 5 months later...
Hey guys,
Was just searching on this for a friedn and realised that I know a guy who was getting the injectors at a great price. The LS1 and XR6T use the same style injectors, so the LS1 style bolt in replacement Motron 60Lb injectors would also work right?
If so, these guys do eight (yes 8) Motron 60Lb injectors for US$379 so surely US$48 per injector + freight and then buying injector clips etc would make them affordable compared to the Siemens Deka ones?
Anyway, the link is HERE
Edited by GTiR Racer
  • 1 month later...
siemens ones. not a whole heap of work really, needed to wire in new plugs and machine up some 12mm spacers to space the rail up. other then that its a bolt in swap.
oh and check out the tutorial section... i made a guide for it also.
Edited by Simon-R32
  • 1 year later...
so for e85 it currently boils down to);
nismo 740cc, can't find any.
deatschwerks $640 pp which is plug and play.
80LB SIEMENS DEKA INJECTORS for around $365 pp plus wiring harness and machining a 13mm spacer.
or ID1000's for $700 but some (lots?) mucking around to install
I had actually toyed with the idea of putting the R33 inlet runners on the Neo head and just using R33 side feeds on the stock rail....but I never got around to confirming the stud patterns matched up, anyone care to check it out?
I know this is an old post but I can confirm this works. I have an R34 neo motor with R33 intake, rail etc on it. You have to pull a stud out of each end of the head and replace it with the standard R33 bolt but it isn't exactly hard to do.
I did it as it meant doing the neo swap was completely painless, running all R32 gear (in an R32) sensors, ecu etc. Just chopped the ignitor off and wired the ecu direct to the R34 coils.
Easy as piss.
Edited by Rolls
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
