  • Replies 138
you need to sign up ..its basically a company that does bidding on japanese yahoo auctions on your behalf (as most japanese sellers wont ship outside japan) organizes your delivery etc but charge a fee of course.
That particular auction is over ..not sure if it sold or if it will be relisted. There's a set of new nismo 480cc's up there right now for $700 but with shipping and other fees it comes to $1k
some other guy i just noticed recently was running Bosch injectors, drop in BUT you just have to fiddle with some wires or something. Apparently very easy and you could practically class as plug and play.
username is Luke ENR34 or something like that
on friday i found a suppy of injectors but they require plug changes (like all sard) and a rail spacer. I will have final kit pricing on monday arvo as i have a kit for testing, once im happy with fitment and tuneability i will update this thread. i am anticipating a big saving.....
there's a big difference between the nismo and sard injectors but ... from what I've read anyway. Apparenty the nismo ones have more spray nozzles and a finer spray pattern which results in better combustion = more power and better fuel economy.
Does anyone know how the deatschwerks compare to the nismo injectors ? Apparently they use 'Denso' brand. 440cc are about $700 delivered
http://www.deatschwerks.com/catalog/produc...products_id=208
hey these are the injectors in which im looking into getting..although i'd be looking at getting the 600cc...would they be fine for 280 to 300rwkw? or are they too big and will make tuning and idle odd?
also has anybody experienced them..i know 1 member on here is using them and was very happy with them.
also URAS let us know how the sard thing goes??
apparently denso = sard ? I just did a quick search for Denso and some people referred to them as SARD. I think 480cc is more than enough for about 300kW so 600cc should be plenty. Remember you will need a PFC or some other ecu management to use bigger injectors.
Hey URAS, let me know how you go with your kit. as i was originaly planning to do a GB once i had all the bugs ironed out (hence my PM the other day)
but if you end up selling them for a good price there will be no advantage to doing the work my self.
another thing i noticed is that the old EF falcon 4L are a cheap way to get EV1 injector plugs.
siemens deka injectors = EV6 injector with EV1 plug
neo RB25 injectors = EV6 injector with nippon denso plug
falcon 4l = ev6 with ev1 plug
falcon v8 = ev6 with ev6 plug
regards
Chris
yes efcourse im going to be using all the proper upgrades to go with it.
so the 600cc wont be too much..as ive heard oversizing injectors isnt a good thing.
there is a 440cc size but im thinking its not enough...for 280-300rwkw.
any opinions??
any opinions??
Looking to do the same :3some:
thinking maybe 680cc hks or something like that
I'm pretty sure 440cc would be good for only about 250-260rwkw. Are you gonna use forged internals ? I wouldn't go above 260kw on a stock engine either unless you have forged internals
ill be going for approx 280rwkw..from what ive read a good tune is whats needed and my engine should be fine.
the tuner im using has a r34gtt with rb25neo and has a gt3540 on it pushing 305rwkw wiht standard internal and has been like that for almost a year with not an issue and still top compression.
Looking to do the same :woot:
deatchwerks do a 600cc straight fitment and plug in made from denso brand parts.
spoke to the guy there and he assured me they will do just as good as standard if not better.
with aussie dollar the way it is, it will cost me no more then $850 delivered to your door...for 600cc's of standard fitment.
pretty good if you ask me...i will let you all know how it goes when i get them.
Awesome!!
Denso make SARD injectors aswell as others. I'm running 550cc Densos in my RB30DET. Perfectly fine, cost me $960 with new plugs though :woot:
SARD = Denso.. see above :P
URAS, very keen to see what you come up with :(
the german sounding ones are just high flows, most likely of stock 350z injectors.
high flowing can be done in oz for much cheaper, so no point getting from the states. Just high flow your factory ones.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
