Hi all,
Its time for another garage cleanout and as usual I have a stack of parts laying around that are going to waste and must go.
1. FET Power Direct Coil Packs (Model Number FPC-001)
FET Power Direct Coils are a high quality Japanese made replacement upgraded coil pack for Nissan RB engines, and are essentially the same as those produced by Splitfire as a drop in replacement. The only real difference is the colour of the coils themselves, in that FET coils are red, and Splitfires are blue. These are in excellent condition and are great value considering the current price of a new set of Splitfires!
Please note these are NOT cheap Chinese coil packs
These coils use the same vehicle compatibility designation as Splitfire, and being 001's they will suit the following:
- R32 GTS-T (RB20)
- R32 GTR (RB26)
- R33 GTS-T (Series 1 RB25 only)
- R33 GTR
I am asking $390.00 Firm
2. Genuine R34 GTR Factory Injectors - Excellent Condition
I have one set of excellent condition R34 GTR RB26 Factory Injectors that have only travelled 20,000 Km's
Perfect upgrade for an RB20, or a cheap and reliable replacement for old and busted R32 or R33 GTR injectors.
I am asking $360.00 Firm
3. Brand New 400R Clear Front Bar Indicators - R33 GTR
This is a brand new set of Clear 400R Type Front Bar Indicators to suit Skyline R33 GTR that I purchased from Japan some time ago. I ended up with 2 sets so I had no need for these ones.
They are a direct fit replacement for the factory amber lenses and are a great aesthetic enhancement for any R33 GTR!
I am asking $185.00 Firm
4. Brand New Carbon Fibre N1 Front Bar Vents - R33 GTR
I have this Brand New set of Carbon Fibre N1 Front Bar Ducts that I ordered from Japan for my R33 GTR and never got around to fitting. These are very very well made and look awesome when fitted, especially if you are chasing the full on JDM look :) I paid a packet for these but given they are just sitting on my shelf looking pretty its time to let them go.
I am asking $175.00 Firm
5. Used Factory ECU - Nissan Skyline R33 GTR
This is the factory ECU out of my R33 GTR that was replaced by my Apexi Power FC.
These are very very handy and worthwhile holding on, especially as a backup in case you are defected.
I have no use for this so its just sitting around and like the other bits its time to go.
6. Brand New Tomei Engine Cover Ornament - RB26DETT
Brand New Genuine Tomei Coil Cover Emblem/Badge for RB26.
This was to be fitted to a new set of painted engine covers I had ready to go on but it never quite made it on to the car.
I am asking $165.00 Firm
7. Used Factory Coil Pack Loom & Ignition Module - R32 GTS-T/R33 GTS-T Series 1
I had this on hand as a spare. I never ended up needing it and it is now of no use to me.
I am asking $150.00 Firm for both items
All parts located in North Sydney - Happy to post at the buyers expense.
Come and get it :D
Cheers.
dang
thanks anyways g luck with teh sale >_<
Lots of pm's but the majority of this gear is still available :rant:
First in best dressed! It all must go!!!!!
Hey mate,
Very Interested in the INjectors, PM me or Call me on 0419 225 146 as im in need of these ASAP .
Cheers, Daniel .
  • 3 weeks later...
would you take $100 for clear 33GTR indicators?
Sorry Simon, but no.
They are brand new and being sold at less than their replacement value already.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
