Item:
Apexi Coilovers to suit GTR $500 + $35 P+H
Pair of white r32 gtr tailights $100 + $15 P+H
Short Shifter Kit R32 $50 + $10 P+H
As Package Turbo Manifold, T70 Turbo, 38mm Wastegate (ebay bought) $500 + $75 P+H
Front + Rear Strut bars to suit gtr $70 each + $15 P+H
GTR Grill Gunmetal Grey $80 + $10 P+H
GTR white faced gauge set for all gauges $200 + $15 P+H
Impul GTR Ecu $200 + $10 P+H
Apexi Power Fc to suit GTR $1000 (willing to go to $800) + $10 P+H
Stock GTR Turbo's $250 + $25 P+H
Splitfire Coil Packs $550 + $20 P+H
Tension Rods $100 + $15 P+H
Stock GTR Injectors $250 Including P+H
Sard 700cc Injectors $600 Including P+H
Think thats all at the moment will let you guys know if there is anything else. Everything here is brand new, except grill, stock turbo's, and stock injectors. never used only looked at, and put back in boxes.
Website: boost and sau
Reason for Selling: dont have a 32 anymore
Price and Payment Conditions: as stated
Pictures: All parts are in storage packed away since i sold the 32 if you require pics pm me or reply in thread
Extra Details: Bought all of this with the intention of putting it into my 32 but i never got around to it and sold it.
Contact Details: pm or reply in thread
https://www.sau.com.au/forums/topic/254792-r32-gtr-parts/
  • Replies 54
all prices negotiably
where exactly is Rocky? what state? plus you just joined SAU need proof of pictures in here too. Sorry to be blunt dude but there is some of not very honest people in here.
https://www.sau.com.au/forums/topic/254792-r32-gtr-parts/#findComment-4400226
Rockhampton, Qld as i cant change the original post, but yeah i know there is dodge people on every forum, as for pictures it says pm me as i have some of them but not of others as they are in storage atm, but if you want pics pm me and you can have them
https://www.sau.com.au/forums/topic/254792-r32-gtr-parts/#findComment-4400233
Send me white guages pixs
https://www.sau.com.au/forums/topic/254792-r32-gtr-parts/#findComment-4400237
May I request pic of rear strut bar please?
Item:
https://www.sau.com.au/forums/topic/254792-r32-gtr-parts/#findComment-4402402
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
