  • Replies 103
when an unoppend can of sprite in the back off your gf's car goes **!KAPHUKING BOOM!** right while you are driving in 43 degrees and now are covered in sticky sprite and ears are ringing...
I couldnt pick up what was left of the can it was that hot...
When you are calling the closest BUnnings to buy a generator and they are all sold out! Every single one of them! I called 3 bunnings to buy one and they were all gone. Had to go to Coburg from Melton!
Now have backup power for fridge and fish tanks of power goes out again!
yeah, but its the western suburbs
:P
My power is yet to go out...
The same can't be said for the whole of Crown last night however...Wouldn't want to see the amount of money lost by the Casino alone, not to mention every restaurant and store in there, as well as every Crown car park...
heres what it looks like at my place
purple is inside, light blue outside
the light blue is slightly higher as the sensor is near bricks (ish)
you turn you aircon off around midnight ey? hehe :P
Same with fans, all out. As was Kmart. Ended up buying one of the last desk fans left in target.
really?
my mums work lost power at around 4:30/5pm yesterday
and it's like 2 minutes from your house
must be on a different grid or something
when you tight ass Indian parents come to you and say
*in an Indian tone*
"son installing the AC in the house was a brilliant idea, fantastic"
hahahahaha
i almost fell of the chair when my mum came up to me and said that
really?
Went out for a bit last night apparently, but I didn't know as I was waiting outside crown to get a steak. Ended up at highpoint porchetta instead after standing outside crown for an hour.
My mate who lives just around the corner from me lost power at his house the other day but mine was fine
+1 LOL!!!!!!
when connex offers free public transport on a day that they know is going to be hotter and expect nothing to go wrong. seriously, do these muppets have half a brain combined at all?
http://www.connexmelbourne.com.au/news.php?newsid=482
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
