So - how can you measure the Pressure in your exhaust? - Simply tap into the collector or turbo area a flared fitting with 3-4mm copper tubing and run it into a boost gauge. I recommend winding a spring like coil of around 5 loops about 10-20cm away from the fitting to shed the heat from the exhaust gases that feed in the boost gauge.
That would work but the trouble with copper is it is a good conductor of heat (thats why they use it bases of saucepans etc)...One of the worst conductors of heat is stainless steel. So using the principle of the coil would work better with stainless tube...Or instead of the coil you could run the tube through a heat sink...I am thinking for more of a permanent installation..Another problem to overcome is if you mount the sensor or WT tank on the fire wall you will always have flexing in the coiled tube which would cause fatigue...
Anyway I am straying away from using EG pressure as an energy source to pump the water...Not because I dont think it is a good idea but because there would be lot of trial and error in getting it to work right. And there appears to be a huge variance in the ratios between EGP and Inlet pressures...So for some setups it would work well and some wouldn't work at all...
I am considering the following two options.
1. Using a pump such as the Shurflo but setting it up in a return to tank set up.ie the pump outlet goes to a T-peice and then returns to tank. Off the T you have the nozzle or nozzles. After the T you have a device** that acts like a rising rate pressure regulator. This is feed by a pressure signal from the plenum...So as boost increases there is more pressure fed to the nozzle...**Dont know what this be yet..It may be a custom job or it may be an off the shelf pneumatic item...
2. Not using a pump at all...Using a pressure multiplier..This is a setup similar to a brake booster and master cylinder..You have a large diameter piston connected to a small diameter piston..The larger piston is fed by boost pressure. The smaller piston pumps the water into the plenum...The big problem with this setup is that it is obviously not continuous..
The amount of water delivered in any one cycle will be the volume of the small cylinder..The system will reset on gear changes or when throttle is backed off. Vacuum will draw the large cylinder back also pulling the small cylinder back drawing in another charge of water...Depending on what you are doing though it may be problem. If you have 15seconds of water in one stroke and you were doing 1/4 miles you wouldn't have a problem..(you would hope not anyway). If you were doing circuit though you may have any issue on the straights..This problem could over come by using a tandem setup that switches or a double acting piston pump. This gets very complicated and expensive and the economics then don't work..
Both options have the ability to deliver water proportional to boost but I think option 1. is the most feasible...
  • 4 weeks later...
on my dirty old VL, I used to run a small bottle that was pressurised by boost with a one way valve, and I ran a windscreen pump(discovery washer by memory) to a very small agg spray nozzle. the nozzle made a tiny jet of water that swirled/spiraled. When the jet hit something, the stream exploded into mist.
I fitted this set up with a pressure switch and ran mostly water/meth through it. It sprayed onto the wall of the pre-turbo piping.
1: very crude, but worked a treat (until water ran out!)
2: never noticed real damaged compressor wheel.
3: water pressure wasnt high enough, sometimes got water droplets on the side of the pipework.
4: needed a much higher pressure pump to make a better mist.
5: The added boost pressure made a HUGE difference in the queality of the mist..
6: The next owner pulled it down to port the head and said that every thing inside the whole engine was SPOTLESS! He said the valves looked like they had just been installed and the pistons looked brand new! hahaha, not bad for an engine with 310 000km on it!
Yep, I'm a fan of water injection, from the power increase ability of it, and also at keeping everything so clean..
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
