Hi,
I will shortly pulling my RB25DET from my R33 GTST S1 along with the PowerFc and Handcontroller
Engine is currently at 120,000 kms, and is available with :
GT3076 turbo - 8000km from new
Splitfire coilpacks again 8000 km's from new
Z32 and the custome pipework to plumb in the turbo to the stock BOV, and inlet equipment.
ECR 33 PowerFC and Handcontroller along with original box and instructions (in Japanese).
I have a brand new set of SARD 850cc injectors still in their sealed packs for the RB25 .
Prefer to sell engine compete - although I will be keeping the power steering pump, alternator and air con pump for the RB30/26 going in, will consider splitting if the price is right.
I also have a second complete RB25 head, a bare RB25 head and an RB25 inlet plenum.
EOI please by PM along with price and I will respond to start the discussion. Deposit will be required to reserve parts. Timeline is likely to be 6/7 weeks.
Engine is currently in car, so pictures will be difficult at the moment, but will try if deemed required.
Thanks
interested in the turbo mate are you willing to seperate also is it internal gate?
Internal gate - fits standard low mount manifold with the supplied spacer.
Do you want to make an offer??
just a little cut and paste from the for sale section. perhaps sticking a price on your ad would be helpful.
1. When starting a new thread, you must include a set price, or at the very least a ballpark figure that you are looking for. EOI's are not permitted, if you want to auction your gear then use e-bay
Thanks for the post -
$1700 for turbo including spacer and all lines
$1300 for Powerfc and Handcontroller in box with manuals
$400 for Coilpacks (splitfire)
$850 for the Set of six new SARD 850cc injectors
Complete engine, minus above would be c.$2500
IF the engine is split, then POA
Price drop on Injectors to $700 also listed on ebay
Injectors currently "selling" on ebay for a bid of $500. If anyone want s them prior to auction finishing, let me know!!
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
