guys I want a few of these units
I'm attempting to rework a few for the Oz market. basically I'm fixing the FM radio and fixing them up.
if you have one I'd like to know. I do not want the the panasonic units (RM-W50SAS)
https://www.sau.com.au/forums/topic/254855-wanted-clarion-oe-radios-ex-c34/
make sure its the one above. there are two versions and they look IDENTICAL.
Oooh I'll check if I still have mine as it may have been thrown out. If not, all I have to do is figure out how much it will cost to send up to Queensland, and it's yours
ok
for those with PN2098E - that one is almost done. new FM front end and a few component changes sorts that side of things out.
band change is easy - getting the FM tuner to co-operate in the fun bit.
thanks go to 66yostagea!
Edited by Chris Rogers
Chris, are you going to want these for a while? or just want a couple so you can figure out what needs to be done to fix them up? i have one just like the one in your first post but i'm still using it, and will be for a couple more months until i get something else.
yep I'm goign to take a few of them. 2098s I dont mind. prefer if the CD section worked. one I redid today needs a laser I think and that is probably going to kill that unit.
would like to get a few of the later ones as the 2098 doesnt like my ipod box.
do you have one like in the top pic and if so do you know who made it? (PN2263E is what I'm chasing.)
acutally take a pic of it in situ. I have both versions here and I'll know the difference when I see it.
are there two different manufacturers for the same faced cd player?
anyway here is a pic of mine. just like the one in your first post.
but like i said, until i get something else to go in its place (a couple of months), im still using it. cd player fuction is good, even play burnt cds without an issue.
there is. pansonic make one that the chassis is identical apart from the rear of it. only difference I can see from the front is a silver volume knob.
yours looks to be a clarion.
if you have teh schematic for that unit - yes please. I have a local schematic for a PN 2371 on the way now.
as that sits ( I have been listening to it fo the past 3 hours now) its a IPOD patch that speaks nissan NBUS on the back of a reworked 2098E. for me it wil make a good test/bench radio.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
