My car is now, unfortunatly for sale...
R33 GTS-25T 130kms
White, Manual
- New heavy duty clutch just installed
- 18 inch Chrome wheels, put on about 5000km's ago
- Full 3 inch exhaust system, hi flow cat, dump etc, cannon rear muffler.
- GFB boost controller
- Autometer boost guage
- Apexi pod air filter
- Five grand stereo (15 inch sub, box, amp, speakers, deck, two remotes
- Momo Steering wheel
- Sunroof
- GTR Body kit, adjustable rear wing
- Recently dyno Tuned at 221.1 RWHP, have dyno sheet to prove
Will send pictures soon...
Looking to get around the 22k mark, but am open to offers...
https://www.sau.com.au/forums/topic/25488-very-clean-r33/
Haha you're right sumfatchin. NEVER believe the kms on an import unless its backed with service history. I can wind my car back to 50,000kms...but you can easily tell it's done heaps more then that.
This guy is selling his car with realistic kms....not ones you see with 50-60,000kms with worn steering wheels and gear knobs.
Good luck with the sale.
https://www.sau.com.au/forums/topic/25488-very-clean-r33/#findComment-557436
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
    • UPDATE: was able to have the bracket repaired and base repaired, seat is like new now ;)
    • I was going to say it looks right out of Gran Turismo photoshoot when you just buy the car. (in a good way)
