Item: 180sx
Website: here
Item Condition: fair
Reason for Selling:kid on the way
Price and Payment Conditions: 18grand or swap for tuff 4door. swap is what i would rather do
Extra Info: front bar and guards need replacing/ repairing
Pictures:
Contact Details: pm me or post here. or email me or add me at [email protected]
wheels /suspension
advan racing 17x9 and 17x8 tri spoke wheels
255's rear 235s front getting close to be replaced
5mm front spacer 25mm rear bolt on spacer
billet 5 stud hubs front and rear from just jap
r32 rotors /calippers front std rear
hot bits coilovers
jic caster rods
aluminium cradle lockers
body/paint
ford envy green with extra gold pearls
including engine bay and rocker cover
30mm wide rear 25 mm wider fronts
full uras bodykit and clear lights to suit
gearbox/ clutch
os giken twin plate clutch.
os giken 1st 2nd 3rd hardened gearset
engine/ turbo
greddy sump
eagle rods
aries pistons
fully balanced bottom end including clutch
arp head/main stud kit
arc race bearing
reseated valves
new exhaust valve guides
all new seals through engine
jun high rev valve springs
jun 264 11.5mm lift in/ex cams
tomei rocker stopper kit
increased presure oil pump
walbro fuel pump
malpasi fuel presure reg
tomei 555 injectors
stainless low mount manifold
garett gt2530 4inch infeed rated at 440hp
gktech exhaust
4 inch intake pipe into standard position for airfilter
hks airfilter
hybrid intercooler kit modified hotside
gfb blow off valve "bovus maximus"
earls oil cooler and filter relocater kit(not on car)
twin electric thermo fans
interior/electrics
apexi avcr boost controller mounted to climate controls hole, controls removed
apexi power fc d jetro series
apexi pen turbo timer
splitfire boost guage
autometer oil pressure and water temp guages mounted in centre airvent in custom mount
kenwood head unit kenwood 6 inch speakers in front
power cable and rca's running to boot
sports steering wheel
bride drivers seat
Edited by yogi_in_a_180
https://www.sau.com.au/forums/topic/254881-180sx-sr20det-sell-or-swap/
whats wrong with the front guards and bar??
guards are both split and bar is chipped
also all tyres recently replaced
new coil packs, the red ones lol
gk tech stainless exhaust
What ECU,
do you have power figures?
how much boost, when was the engine built and who by....
can u put up photos of the damage?
Edited by axe s
What ECU,
power fc d jetro the one with a map sensor
12psi atm
engine built bout 15,000 klms ago by myself
never had a full power tune only but was dyno tuned to run without leaning out made bout 260hp
will try get pics of it soon gotta charge digi cam batts
pics of anything else?
    • Just read this... Just a little bit of a wild one! Do you think the driver was testing out a new feature/device for how to lose the cops in a high speed chase?   I also suspect, if the box has a road sweeper that does magnetic metal pick up, he does a LOT of work in the machining industry. Which is what most of that looked like, machining chips from a mill or lathe. And I bet they're RAZOR sharp! And from an environmental perspective they really do need to actually collect all of those little pieces too. I wonder how many people still cop flat tires over the coming months on that road?   As for insurance company, yeah, it'd be interesting to hear what they say to the owner. But realistically, he's right, that "It's his fault". In the way that, it was his truck that spilled it, so they need to clean it up. However, neither he, nor his insurance company may bear the end cost if they do an investigation and find out it was caused by someone elses negligence (And they know who)...
    • Yeah, no matter what bad things people can say about Julian from Autospeed, he at least was capable of thinking and his inclusion of a check/relief valve in the plumbing for the Audi boost controller, that I made a copy of and used for years**, completely eradicated that problem. **It's still lying on my workbench where I put it about, um, 18 years ago and have never found a home for it!
    • I didn't actually know this! I've seen photos of the H1, mainly outside shots, and they just look "different". I guess there'd be a few little changes like nicer rims, and probably the fact they have nicer looking paint with some depth and shine, which will make any vehicles body look different to the very flat colours of the defence force.   I've watched the guys on GHPC convert their Humvee to LS1, and they've done some really nice front shock upgrade. I'm waiting for the next video on it with the rear end done. I can't remember if they've already done it, or I dreamed it, but I believe they're also supercharging theres. They will be in the future doing proper long travel suspension too.   If you ditch out your big V8, as rubbish as it must be, send it to my place. I'll let the unreliable V8 motor and box be here. I just like V8s... So I'll find something to do with it... Even if that something is just taking up valuable space in the yard. I might have something Skyline I can send back in payment... Or even Ford Barra motors  (From memory you're in Canada yeah?) So you can then play with the legendary Aussie 4L version of an RB...  Except they don't have that distinctive random miss at idle like the RB25 does.
    • Or you mean the age old problem of early 2000's manual boost tees, where they never let the pressure out of the line between the boost tee, and the waste gate, so after your first trip on boost, the damn wastegate liked to stay open and be laggy on gear change?
    • Being behind an RB25DET, we know he won't have the small box for long at all...
