the only thing is the licence must say national rally. a guy went to service tas with his cams national rally nav licence, and they said no becasue he dosn't drive. so we whipped out his aasa national rally licence, and he got his si plates.
Josh....sounds like you have the same sort of idiots we do in our RTA. WTF is the point of rally import if you cannot register a rally imported car. Because you can't rally an unregistered car either.
They told me a race only import was for racing on race tracks where you wouldn’t require rego. I kindly referred him back to Targa Tasmanian (I figured even this douche bag knew of the event) and asked him to explain to me how there are race only cars on race only rego competing.
What can you do though, these guys control the system, abuse them and you’ll have no hope.
Here is the thing. I warned a friend about this early last year after hearing some CAMS guys telling me that the strings were going to get tightened.
The Rally Reg was originally introduced so that cars that were not released locally could be raced in state and national rallies. ie EVOs and STIs etc. As others have said the cars needed to be registered for transport stages etc
The rego type was never intended for people to be importing cars that can be complied and registered. The warning i got was if i get a race rally import, makes sure that the car isnt eligible to be complied. If that model can be complied then import it properly and get proper registration for it.
So i dont agree with it, but i know that there were people complaining how some high profile tarmac cars should not be running rally rego and only dirt/gravel rally cars should be allowed to run this rego.
So it seems there is people pushing agendas and its a matter of whether you are lucky enough to be talking with one of the for people rather then the against
hang on Roy.....are you trying to say the people high up in CAMS are too busy playing politics to encourage people to get out and race in any way possible!???! No way.
its right though. The scheme was designed for rally cars to allow them to be used on the road (as they have to in a rally). Its not intended to allow a circuit race car to drive to/from events. My understanding from when I was rallying was that you had to have a National Rally Licenece and the car had to be CAMS log booked as a rally car. The Rego used to be cheaper but isn't any more in QLD if my memory serves.
Thats my belief too Harry, NR licence and CAMS vehicle log book.
And I've heard there's a bit of paperwork hassle come renewal time too... like the vehicle is required to compete in events or something...... although how they could police that I'm at a loss to explain, like, the car could be in a shop for repair for a year easily.....
LOL, i have some interesting conversations about "grass roots" motorsport around camp fires in the bush with regards to making it accessible. It seems they want everybody out in the bush not on the black stuff. Which is strange since rallys require massive amounts of coordination with Parks and Wildlife, residents etc vs cash for track owners. I dont get it
Simular issues here in WA too, used to be able to rego a car for tarmac, or gravel, however, as a new scheme was meant to be comming in, and it hasn't one ass clown has taken it apon himself to can any car getting rally rego, unless it will be used on one dirt rally a year..
which is all well and good if your going dirt, but all the tarmac boys cop it in the ring, and given the ARC is basically dead, and even club level dirt rally is in a slump at the moment, most people are going tarmac, understandably because it cheaper and your less likely to total a car so in WA its extremely popular now, so this one ass clwon is helping no one escept the few who are going dirt..
if and when the new scheme comes in it will be a lot easier for all concerned and get rid of the issue of cars kicking around on b-reg as daily drivers, and there are a lot of s6 sx7's like that...
  • 3 weeks later...
Bumping this thread
Two possible solutions so far:
1) Hook up with a cousin and move to Tasmania
2) Fit some 15X6s, stocker suspension and enter a few bush bashing events
Edited by aleks
    • My theory would revolve around the ~4000rpm point being peak torque territory on an RB, where you're supposed to be looking at max efficiency of the head, etc, and....just not having it because the skinny ports are doing something to f**k it up. I'll admit, it's a loose theory.
    • It could be in the tune but in both cases it couldn't be completely solved or eliminated by some of the best tuners in victoria so I'm DOUBTFUL that it's in the tune or ECU but stranger things have happened of course. I've pondered that theory too but is there any theories that thinner and smaller ports overall would cause a turbo to spike? I would've thought it would just restrict it in general if it was small enough to make a difference. I wouldn't expect it to make a different at what is essentially sub 300kw at 4000rpm anyway. I think the next step is going to have to be the 6psi spring to rule out the idea that the gate is cracking open far too wide initially. At least that is the cheapest (free) thing to check initially.
    • I'm thinking it is skinny NA Neo port sizing and cams. Somehow.
    • -5’s did it. 8474 did it. Not hot side related. ECU related? 🤨🤪
    • Above you mentioned you only need to sand primer if there's an issue with it but with fillers it says the surface needs to be sanded to X grit beforehand. Does that sorta contradict that point as the primer hasn't been sanded yet? At the same time if I sand the primer, there's a good chance I'll expose the bare metal and I'm just chasing my tail at that point. Or I'll just use a sand sponge instead of sandpaper, it seems to be far finer in terms of abrasiveness as opposed to sandpaper. From what I understand, filler is like primer and needs scratches from the sandpaper to help it adhere to the panel. I realised the way I'm doing things is actually a bit counter productive as there's a chance after I put filler I will need to put epoxy primer again as opposed to putting the filler first and potentially no primer if I don't go to bare metal. Will keep this in my mind for the rest of my repairs.
