Recently i have noticed when i put my foot down in first my r34 does not seem to be boosting right!!
The boost gauge on the center console is reading normal but the car does not feel well. This happens every now and again but more than i am happy with.
It feels like there is no turbo lag at all but not in a good way, it just revs all the way up without feeling the turbo kick in!
Can anyone help me or give any advice? the car is regularly serviced every 5k.
cheers Luke
https://www.sau.com.au/forums/topic/254896-unwell-r34gtt/
+1 for the clutch. Sounds like everything else is running fine, & the driveline just isnt transferring the power to the ground.
Your tyres werent slipping with lots of white smoke were they?? :D
I would check clutch also, maybe a quick power run on the dyno could shed some light on it for ya.
https://www.sau.com.au/forums/topic/254896-unwell-r34gtt/#findComment-4399028
its not traction controll is it ? my tires make f all noise and even less smoke if i take it for a skid in RWD.
also conisder the weather . my cars "feels" noticably slower on a hot day
clutch is easy to diogniose and so is traction controll
https://www.sau.com.au/forums/topic/254896-unwell-r34gtt/#findComment-4399093
na, no tyre smoke. it doesnt sound like my clutch is slipping hmmm, i might just take it to a guy and well see what he says. this is strange because it is only every now and again surely if it was clutch it would be more like all the time??
any different on a hot day? slightly but nothing much. i could be driving and it will be shit 'ot but ill stop at lights and take off and will just be shit?
https://www.sau.com.au/forums/topic/254896-unwell-r34gtt/#findComment-4399379
heat soak????? not sure if a faulty knock sensor would cause this, but i could be wrong. the car is using more fuel than normal really drinking it, i first thought faulty o2 sensor maybe?? conditions? weather wise cold day hot day doesnt matter engine sounds normal but doesnt seem to be any major pick up like the turbo isnt spooling up at all!!! just doesnt throw you into your seat at all but sometimes it does run fine! i was looking in the engine bay before and the air pod is stuck in the corner of the engine bay thats why i thought maybe shit airflow but i never done this before and the airpod hasnt moved!!!
HELP
https://www.sau.com.au/forums/topic/254896-unwell-r34gtt/#findComment-4400295
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
