Recently i have noticed when i put my foot down in first my r34 does not seem to be boosting right!!
The boost gauge on the center console is reading normal but the car does not feel well. This happens every now and again but more than i am happy with.
It feels like there is no turbo lag at all but not in a good way, it just revs all the way up without feeling the turbo kick in!
Can anyone help me or give any advice? the car is regularly serviced every 5k.
cheers Luke
https://www.sau.com.au/forums/topic/254896-unwell-r34gtt/
+1 for the clutch. Sounds like everything else is running fine, & the driveline just isnt transferring the power to the ground.
Your tyres werent slipping with lots of white smoke were they?? :D
I would check clutch also, maybe a quick power run on the dyno could shed some light on it for ya.
https://www.sau.com.au/forums/topic/254896-unwell-r34gtt/#findComment-4399028
its not traction controll is it ? my tires make f all noise and even less smoke if i take it for a skid in RWD.
also conisder the weather . my cars "feels" noticably slower on a hot day
clutch is easy to diogniose and so is traction controll
https://www.sau.com.au/forums/topic/254896-unwell-r34gtt/#findComment-4399093
na, no tyre smoke. it doesnt sound like my clutch is slipping hmmm, i might just take it to a guy and well see what he says. this is strange because it is only every now and again surely if it was clutch it would be more like all the time??
any different on a hot day? slightly but nothing much. i could be driving and it will be shit 'ot but ill stop at lights and take off and will just be shit?
https://www.sau.com.au/forums/topic/254896-unwell-r34gtt/#findComment-4399379
heat soak????? not sure if a faulty knock sensor would cause this, but i could be wrong. the car is using more fuel than normal really drinking it, i first thought faulty o2 sensor maybe?? conditions? weather wise cold day hot day doesnt matter engine sounds normal but doesnt seem to be any major pick up like the turbo isnt spooling up at all!!! just doesnt throw you into your seat at all but sometimes it does run fine! i was looking in the engine bay before and the air pod is stuck in the corner of the engine bay thats why i thought maybe shit airflow but i never done this before and the airpod hasnt moved!!!
HELP
https://www.sau.com.au/forums/topic/254896-unwell-r34gtt/#findComment-4400295
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
