My friend had one of these when i was in year 12 and when he turned 18. It was his dads old car and it was in allright condition but we trashed the shit out of it and he ended up rolling it, and it was a writeoff.
Pity, we thought it was just an old heap of shit back then
https://www.sau.com.au/forums/topic/25492-mad-old-skyline/#findComment-546004
Yeah, thats a C110 skyline (so is the purple/silver one) - The car you speak of , INASNT, would have been a datsun 240k, which is the same body. However, the Aussie delivered 240k was basically the bottom spec GT skyline, with an even lower spec L24 from the current-at-the-time Laurel sedan. The jap one got fruit like twin SU's and higher comp in the L24, and the option of the GT-R model with a S20 2.0 litre DOHC six.
You could build a nice replica gt-r off a 240k though...
In short, INASNT, 240k's are getting more valuable, but in comparison, cost wise to a jap GT skyline, "piece of shit" is still where its at in the price stakes.
cheers,
floody
https://www.sau.com.au/forums/topic/25492-mad-old-skyline/#findComment-546185
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
