Garrett GT3082R Known as GCG GT3071R-82
Dual Ball bearing turbocharger
Oil & Water-cooled bearing system
High Performance BCI-18 Garrett Compressor and UHP Turbine
Perfect for high-horsepower, smaller displacement engines at elevated boost levels
T3 turbine inlet flange, wastegated with 5 bolt outlet flange
Turbine housing is cast from high-nickel "Ni-Resist" material for extreme applications
Actuator included and standard 14.7psi pressure.
Hey guys this is the new turbo i have just recieved from GCG for my Skyline R33 , If you look on their website they have a version Called the XTRGTST3071r. THis is what i ordered but i recieved a call saying they dont use a modified version of the RB series compressure housing they have a new model which use's a Garrett housing which includes an Internet waste gate which is quite significantly larger then the old series and it is also blocked off from exhaust gas. Also you can get the front housing polished back like i have :P
The only drama is now i cant use my standard dump pipe and i cannot find any such dump pipe which will suit it . Here are some pictures and yeh i was running an old 45v3 nissan turbo with Injectors , Walbro Pump , SARD FPR , Pod Filter , Apexi SAFC Neo with VG30 Airflow making around 218RWKW @ 14.1 PSI on Stock internals , what power should i expect from something like this running at the lowest setting of 14.7PSI?
Edited by gL3nJaMiN88
https://www.sau.com.au/forums/topic/254939-garrett-gt3082r-gcg-gt3071r-82/
What size is the turbine housing? .82 or 1.06?
I personally am not a fan of the 82mm comp wheel paired with the 60mm GT30 turbine wheel. It makes for a lazy turbo that needs good fuel to make the most of it.
They were good back in the day when the 76mm (HKS3037S) style compressor wheel wasn't available for the Garrett line up.
Edited by TheRogue
Well they said its just been released it replaced the XTRGTST3071R , The badge on the turbo says " GT3071R-82 " any idea's where to get a dump pipe or is it custom made only
So where should i get a dump pipe from ? or will i have to get one Custom Made from a GT30 Flange?
Get an aftermarket XR6 turbo dump and chop it/adapt it to suit.
Or you could just get a custom one made from laser cut flange.
That turbo should be good for easy 300rwkw - sorry, just read the 1 bar thing again - As above 250rwkw at 1Bar
If you ask Brett at GCG he could probably sell you a flange plate to match the housings outlet , need to make a dump pipe using that flange or one like it . GCG/Garrett/Ford should be able to supply the gasket .
A .
PS if the turbo still has its Garrett ID tag the cartridge (CHRA) number from memory is 700177-14 or -5014 for a GT3082R .
Unless the housing has been modified, there should be a number cast inside it, just near the mounting flange to indicate the A/R.
Logic says that the -82 suffix would indicate a 0.82 housing, but they've put a model number of 3071 that does not appear true to type.
looks like a 3071 to me and i don't think gcg would badge it incorrectly either. I dunno where you get 3082R from? the cart will have -23 or -5023 on it. If gcg mod a turbo away from garrett specs they will remove the original tag and rebadge with the original numbers in addition to their own serial number to identify that individual turbo.
It also looks like they have started enlarging the wastegate flap over what was originally offered by garrett. I had massive boost control issues with the same turbo in .63 and ultimately went down the path of an enlarged wastegate with some success.
Skylinecouple runs virtually the same turbo, only difference would be the wastegate size and his has a surge modded cover.
I would advise against the gcg flange unless you are prepared to do a lot of work with air saw and grinder or a mill. The wastegate port is (or was anyway) grossly undersized.
I have my old dump/front pipe available if you are interested. It was to suit an r32 but it will save you a heap of work even if you just chop off the dump section and get some new piping added by an exhaust shop to match your exhaust.
I had a closer look at the above snap of the compressor side and I'm reasonably certain the compressor housing is T04E family not T04S so theres a good chance it's a GT3071R - with one of Garretts GT30 T3 flanged IW turbine housings .
The air inlet boss has been machined down to accept a smaller duct than one designed to fit the std snout .
Is Brett offering a kit to suit RB25s ?
Also URAS can I have a link to the thred you made recently .
Cheers A .
Edited by discopotato03
hey guys thanks for the reply's i ended up calling GCG and they have a new Split Dump that has a solid steel split just like on the IW Housing , it looks like a very impressive dump pipe compared to the cheap split ones i've seen . Ill post a picture up tonight but i've got everything i need now so just about to get ready to fit everything ill let you know how it all runs but yeh it is def a 3071r just a different exhaust housing to the original GTST one they make for bolt ons
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
