Hey guys,
just seeing if anyone is in the opposite situation to me...
have a GT2871 that i'm about to put onto my s13, however it has the .86 rear housing, and im looking for a bit of response, so does anyone have the same turbo but with the .64 or even .49 rear housing and are looking for the .86?
not really keen to post either...
Thanks
Chris
https://www.sau.com.au/forums/topic/254944-2871-86-rear-housing-for-swaps-only/
