I sell split systems at my work.
Pete I can see what I can do if you want?
Personally Id suggest the Mitusbishi units or even the kelvinator (electrolux).. Got a 1.5 HP Kelvinator Inverter for around $800. Got a mitsi 2hp, can see what I can get that for if ur interested?
  • Replies 47
yes please flicky...just get a few prices for a 25 squ metre area (std height ceilings) if that's OK....not sure if 1.5 hp would be enough or whether I need a tad bigger?
cheers
No probs pete! Id say 1.5HP would be fine for that size but i can check on our programme we have at work, we can enter in measurements and room sizes etc to get a better idea.
Will let you know tommorow
mitsubishi are really good too
reliable, freezing cold, usually a bit cheaper than the fujitsu etc. theyre well made units. forget the chinese ones. they dont even conform to their own specs.
a 2hp for a single room would do the trick
i have a 3.5 hp in the loungeroom and it reaches most of the house.
x2 for the Mutsubishi units.one of the best on the market. Ive owned 3x 3.5hp units and wouldn't buy anything else. Pay for a holiday to SA and ill install it for you.
Yep, evap can eat my buttocks.
I don't care how cheap the thing is to run if there's no difference with it on or off!
Ducted Daikin inverter here - cost a few beans to do, but when it comes to my comfort in summer and the comfort of pregnant women and babies / small children I couldn't put a price on it.
i got too admit we have ducted evap that works really well MOST of the time and does a great job BUT there are a few days of the yr where the evap just dosent make the grade .
hence why i want to put a split system in the family room . the family room and the kitchen are really one big room separted by a island type bench . but as we spend most of the time in the family room i think we would benifit from the split . actually it really dosent even need to heat as we have a wood fire and a gas heater there . but refrige cooling would be great .
enough of my ramblings .
cheers dean
evaps are fine if you buy the right brand and more importantly the correct "hp" motor....always best to get bigger then you need so the unit isn't struggling to work properly.
Just like buying a turbo! :)
Currently have a cheapo 1hp Chinese branded split type A/C (branded "Chillair") in my room, that my parents bought in some Chinese A/C shop. Unit is just over $300 (MUCH cheaper than any other 1hp models that we saw in the main stream shops) & I forgot how much the install was; my parents called up tons of places & found a Vintam guy to install it for the cheapest price.
The A/C is about as generic as you can get, standard compressor, not a inverter model & pretty much just set the temp buttons & on/off switch. No other features, but it works wonders. can cool my room to under 18C when its about >40C outside.
Also the main living room is fitted with a massive old box type National branded A/C, it may be old & may make a sh*t load of noise when on, but it totally kicks the crap out of all the evap units family friends have in the cooling department.
Edited by Mayuri Krab
YES!!! We have a national 2.0 or 2.5hp wall unit, circa 20 years old, and STILL blows 16 degrees set on cold. Hasn't missed a beat! Gets helped out by the new daikin 2.5hp inverter on real hot days tho.
    • Just install a grease nipple into the centre of the outer steel of the FUCA. Make sure the bushes aren't long enough to touch each other underneath that nipple. Cut a few mm off each if need be. Then you can push grease in there while it is all assembled. That was the very first thing I did (to all 4 ends) of the FUCAs on my 32 when I put Whiteline adjustable bushes into them. They would squeeze the grease out real fast, and I could squeeze it back in faster.
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
    • I would sell those side feeds before you hydra-lock a motor. I won't say too much about Yellow Jackets because I'll hurt people's feelings, however ask those that tune RBs day in/out what they think of them.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
