  • 1 year later...
when will people get the new imports in for sale?
in particular the stagea and chaser?
anyone one got any ballpark figures for the chaser?
sup dude, i know that stagea and chaser compliance are more that the run of the mill imports e.g. r33 s13 etc. about $5500 and the are available already. there are a few good sites around one in particular i just finished checkin out was imports101.com its a new site and i contacted them and they said they could get the plates because i was keen on a chaser. wat one do you prefer the stagea would be a good family drift car hahahahahaha or drift in stlye (chaser) sick.
peace.....
https://www.sau.com.au/forums/topic/25498-new-imports/#findComment-1027994
peace.....
Check with http://www.autowholesale.com.au/ as they have the cars and as far as I know the last plates in WA, http://raws.dotars.gov.au/rawswebpublic/rawpubmain.asp will tell you who has plates and ask them if avialable and how much before buying a car.
https://www.sau.com.au/forums/topic/25498-new-imports/#findComment-1028433
