hey guys,
ok so first, got my rb25 running in my r32 today, on cold start it idles at 1000rpm then on hot it idles at 500rpm but if i rev it and let it drop it will stall, so to adjust that do i just wind out that thing with a brown plug? under the purple acc valve? i had to replace it as the brown plug was broken so i just wound it all the way in,
also with this as i put the revs up a bit with the accel cable, as soon as i move the tb a tiny bit i can hear a lil click? is that the vct? im guessing it is but if any1 can run out to there 25 and start it and test this? if not what could it be?
Then with the thermostat, i had to change some welsh plugs on the thermostat side so i took the thermostat out, when i started the engine today i let it heat up, (left both bleed valve screw in and radiator cap) as i wanted to see if i fixed the welsh plug, didnt want coolant going around the welsh plugs i replaced,
so the temp hit 90 on my defi gauge (sensor is in top pipe) so is either my thermo stat gone? or is it because of air lock that it didnt open up?
o also while im at it,
could i get part numbers for:
thermstat (if i need 1)
Ps belt (series 2 stagea motor) (3PK belt)
i think thats it, any info would be good thanks,
Cheers JV
ok guys, i ordered the belt, i ordered a 3pk855 which should be fine,
thermstat should be fine to with a bleed,
just need to adjust this idle,
the colour plugs are purple and brown, the brown is the acc and the purple is the one my mate told me to twist out to bring up the idle, can any1 comfirm?
ive uploaded pics to so you can see the plugs,
Cheers
with engine warm you need to disconnect the tps sensor and adjust idle screw at back of iac assembly to 600rpm, then reconnect the tps and idle should be correct.
that is the basic run down, i have posted full procedures in the past.
only on the early rb engines you disconnect aac valve plug, rb25det is different procedure.
also the nvct is activated/advanced off idle, so yes the clicking will be the nvct solenoid.
    • With stone chips, you really can't just try to fill them. You really have to sand that spot to lower the edges of the chip, so that the filler will end up covering a wider patch than just the chip. Otherwise, you're trying to have a sharp edged paint surface match up to some filler, and they just do not sand the same and you always end up with a noticable transition. A bunch of adjacent chips should be well sanded back, to round off all those edges, and use a lot (in a relative sense) of filler to raise the whole area back.
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
