Item: Wolf 3D V4(V400) Plug and Play with Hand Controller
Condition: Good... Few scratches on ecu case(not that you ever see it).
Price: $950
To Fit: R33 GTS-T
I am selling my Wolf 3DV4(V400) Revision 7, Plug and Play ECU with Hand Controller to suit R33 GTS-T. Possibly fit R32 and GTRs(not 100% sure, check with Wolf). The current map on the ecu is for an RB25DET with upgraded turbo, injectors, fuel pump etc.
Some details on the Wolf unit(collected from other posts):
The Wolf 3D Version 4 is fully 3D tunable for both fuel and ignition timing! These ECU's are an excellent unit with incredible tuning resolution, both ignition and fuel can be adjusted every 125rpm with 16 different load bands. Thsi compares very well compared to Microtech that can only be changed every 500rpm with less load points. Having such a fine tuning resolution is perfect for getting the most out of your modified engine. No need for a Z32 AFM with this ECU, simply remove your AFM all together. Overall this ECU provides sharp, crisp throttle response whilst still maintaining factory drivability e.g smooth idle, fuel economy, cold start etc, something impossible with many of the competitors ECUs.
Some of the benefits of fitting a Wolf 3D V4:
Make the most out of your modifications
Excellent drivability, Wolf 3D V4 features full cold start and air temperature adjustments
Easily retuned if you change a modification
Crisp and smooth idle
Excellent fuel economy
Ability to remove AFM. ECU is MAP sensor based so no need for a Z32 or the airflow restriction a AFM causes
Boost controller can operate with factory solenoid
In Built Turbo Timer
Security Pin Code(Car won't start till code has been entered - backup for your alarm/immobiliser)
Can run multiple Maps with live map switching while the engine is running(Power Map, Economy Map, or Low Octane fuel)
Specs:
Tune from either Hand Controller or PC Software
Maximum Engine Speed 20,000RPM
Fuel Map every 125RPM to 16,000RPM
Fuel Map has 16 Load Bands
Ignition Map every 125RPM to 16,000RPM
Ignition Map has 16 Load Bands
Idle Speed Control with Water Temperature Compensation
Sequential Fuel Injection
I have attached a number of pics(including the unit powered up). Unit was $1790 new (ECU $1395 +HC $395). Looking for $950. Will post. Contact me via PM.
Edited by crazy1
https://www.sau.com.au/forums/topic/255006-wolf-3dv4v400-with-hand-controller/
