Item: Wolf 3D V4(V400) Plug and Play with Hand Controller
Condition: Good... Few scratches on ecu case(not that you ever see it).
Price: $950
To Fit: R33 GTS-T
I am selling my Wolf 3DV4(V400) Revision 7, Plug and Play ECU with Hand Controller to suit R33 GTS-T. Possibly fit R32 and GTRs(not 100% sure, check with Wolf). The current map on the ecu is for an RB25DET with upgraded turbo, injectors, fuel pump etc.
Some details on the Wolf unit(collected from other posts):
The Wolf 3D Version 4 is fully 3D tunable for both fuel and ignition timing! These ECU's are an excellent unit with incredible tuning resolution, both ignition and fuel can be adjusted every 125rpm with 16 different load bands. Thsi compares very well compared to Microtech that can only be changed every 500rpm with less load points. Having such a fine tuning resolution is perfect for getting the most out of your modified engine. No need for a Z32 AFM with this ECU, simply remove your AFM all together. Overall this ECU provides sharp, crisp throttle response whilst still maintaining factory drivability e.g smooth idle, fuel economy, cold start etc, something impossible with many of the competitors ECUs.
Some of the benefits of fitting a Wolf 3D V4:
Make the most out of your modifications
Excellent drivability, Wolf 3D V4 features full cold start and air temperature adjustments
Easily retuned if you change a modification
Crisp and smooth idle
Excellent fuel economy
Ability to remove AFM. ECU is MAP sensor based so no need for a Z32 or the airflow restriction a AFM causes
Boost controller can operate with factory solenoid
In Built Turbo Timer
Security Pin Code(Car won't start till code has been entered - backup for your alarm/immobiliser)
Can run multiple Maps with live map switching while the engine is running(Power Map, Economy Map, or Low Octane fuel)
Specs:
Tune from either Hand Controller or PC Software
Maximum Engine Speed 20,000RPM
Fuel Map every 125RPM to 16,000RPM
Fuel Map has 16 Load Bands
Ignition Map every 125RPM to 16,000RPM
Ignition Map has 16 Load Bands
Idle Speed Control with Water Temperature Compensation
Sequential Fuel Injection
I have attached a number of pics(including the unit powered up). Unit was $1790 new (ECU $1395 +HC $395). Looking for $950. Will post. Contact me via PM.
Edited by crazy1
https://www.sau.com.au/forums/topic/255006-wolf-3dv4v400-with-hand-controller/
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
