  • Replies 43
Hey chris i might have someone buying front and rear. Just waiting to see what happens there but if it falls through ill let you know.
Most of the interior is stripped, still have:
- 2x rear GTR door trims (blue/grey color)
- seatbelts
- dash
- carpet
- roof lining
- rear parcel (does not have speaker plastics)
- Nismo leather gear stick
- roof lights
- power window switches
- glovebox
- rear vision mirror
hey im after the sard fuel pressure reg. , adj exh cam gear and clear side blinkers was wondering how much?
also was wondering what oil cooler kit is it and how much for that.
thanks
Edited by Just_Rb
thanks
Reg and fuel rail setup look like they are sold along with the fuel system in boot. Cam gears are sold. Clear blinkers are sold. Oil cooler kit is from Motorsport Connections (www.mscn.com.au) and is fitted with speedflow fittings/lines etc.
Got standard wheels still mate? Whats the rubber condition like??
No have sold my wheels. Only have a set of MT Street radials (x2) on 300zx rims
How much for the master power window switch?
$60
any chance you have the series 1.5 front bar? the pics make me think no but no harm in asking :D
No i dont just have a GTR fibreglass bar
do you have the factory airbox by any chance?
No sorry I only have a apex pod for sale
  • 1 month later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
