I'm trying to stick my apexi safc to the dash but I can't get anyhting that will hold :)
After some advice I went and bought outdoor/automotive double-sided tape from Dick Smith but it still doesn't work...same problem with my mobile holder.
Can anyone recommend some sort of double-sided tape that will stick it to the dash, and not come off in the summer heat? I've thoroughly cleaned the parts of the dash that I'm using for this with metho to make sure there is no oily residue on there, but nothing is working.
https://www.sau.com.au/forums/topic/25504-sticking-things-to-dashany-ideas/
Don't glue it that would be shit .. what happens when you wanna take it off
For my turbo timer I tried using double sided tape but that was crap. Now I've got that velcro stuff with supersticky backing. I dunno where you buy it from as I pulled it outta my girlfriend's mum's sewing box :) But I cut strips of that and put them on the timer and stuck in to the dash. Works a treat.
Tek screws :)
The japs seem keen on screwing stuff to the dash...not sure why, for me, screwing through the dash is a last resort.
Tried cleaning the surface of the dash with alcohol before you stick anything to it? Alot of the time its stuff like armorall etc. that causes it not to stick.
Red17
like red17 said, clean the area first! i usually use bug and tar remover (the spray on ones from turtle wax) to clean the surface, and then use some good quality double sided tape like the ones from 3M. it works a treat!
alternatively, u can use clear silicon (like the ones for your bathroom) they stick well and would peel off if you ever want it to.
I used a good double-sided tape (from Autobarn) for my AVCR and RSM on the dash. I needed to bend the Apexi stands so they were flush with the dash though.
I cleaned it first with metho, and clamped it down with masking tape overnight - has been fine for 6 months.
You could use black silicon stuff.... Its not actually silicon, but i forget the name.. It just dries a bit stiffer. And if you ever want to take it off the use a hair dryer to make it soft and pull it off.. then clean the dash with keroscene.
Well thats what I would do. Might be hard to get it off tho., but can stil be cleaned off with kero.
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
