Hey guys
So my i think my clutch is starting to go... and as far as im aware it has never been changed... there was no details on it when it came from japan on whether it had been changed or not.
Ive already worked out who im buying it off.. that would be Kudos as i have bought from him before and his service is just AAA...
Ive been researched what clutch to buy for a good few months now as ive been expecting it to go at anytime.. and im stuck between the exedy hd button and exedy hd cushion button. Cushion button is about 100ish dollars more... is it worth the extra dollars? Is itmore of a comfort thing or performance? Can anyone who has these clutches shed some experience on this for me?
Just a quick run down on the car...My car power wise is more or less stock. (I find modding for handling more fun and rewarding). And probably the most i would do is tune with the SAFC 2, boost would more or less stay the same. So we are looking at stockish power.
https://www.sau.com.au/forums/topic/255052-clutch-change/
Havn't used exedy but have been told the cushion button helps with drivability. Running an Extreme ceramic in my 33 with the sprung centre and 850kg pressure plate, good clutch even in slow moving traffic
https://www.sau.com.au/forums/topic/255052-clutch-change/#findComment-4400682
how much was that one?
As my budget is around the 500 dollar mark for the clutch kit it self...
Any personal experinece with lighten fly wheels as well? Ive search and read a few threads but no conclusive thread on whether i should spend the extra dollars on one or simply machine the old one.
I have read that the cushion button does not hold as much power as the button clutch... is this true?
https://www.sau.com.au/forums/topic/255052-clutch-change/#findComment-4400742
The Cushioned Button Clutch isn't recommended to hold High HP (250KW+) compared to the Sprung Button (Puk) Clutches, But in saying that the difference between the HD Organic & Cushioned Button is merely the Clutch Disc you'd prefer to run, With The Xtreme Clutches, Both have the same Clamp Load (850KG's) The Cushioned Button has Good driveability & isn't too heavy on the pedal but can take a bit more punishment then the Organic,
The Xtreme Cushioned Button Clutches are between $550-$600 incl GST from memory...
With the Flywheel, Honestly I'd just machine the original F/W... It's only $30 or so depending on where you go & the performance aspect won't be noticed in this case, If the old F/W is beyond machining then perhaps find a 2nd hand F/W from a wrecker, It's a far cheaper option & as long as it gets machined you shouldn't have any dramas :ermm:
https://www.sau.com.au/forums/topic/255052-clutch-change/#findComment-4400846
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
